Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Wont start let omeone use , we think they put reg gas in
  • Jim1969pa3
    Jim1969pa3 May 11, 2010
    Will it turn over at all?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Remove muffler and inspect piston, rings, and cylinder through the exhaust port. If any vertical scoring is visible you may need a top end rebuild, if not may be dirty fuel filter, cracked fuel line etc.
Posted on Apr 13, 2009
Mini Cooper 57 reg wont start
if you have spark and gas the only other things you need are compression and timing- cheers Denny
Dec 21, 2013 | Mini Cooper Cars & Trucks
Diesel 6 0l
Every diesel has an electric solenoid that shuts the fuel off when you turn the key off. I suspect that is your problem but I don't know where it is exactly on a Ford. It should be mounted on or near the injector pump.
Oct 25, 2013 | 2002 Ford F350 Super Duty DRW Reg. Cab
316 m reg, ran out fo fuel put some petrol in and now it will not start don't think the fuel pump is working is there a reset for the pump
Un firtunetly pumps with some age on them tend to lock up when ran dry. try hitting the bottom of the gas tank about in the center or where you think the pump may be. The vibration usually knocks them loose and they start pumping again. You might have to smack the tank 2 or 3 times. You will still need to replace the pump because they can continue to lock everytime you shut the car off. And eventually you wont be able to smack the tank to get it going.
Jul 03, 2011 | BMW 318 Cars & Trucks
I have a 2001 525i w/ 6 cyl. it wont start. put spark tester on each plug,they spark. put gas in it, have fuel coming out of fuel line (took filter off) when key is turned on. how can i test the filter? it...
ok on that model of bmw you need to change the mass air flow sensor it controlls the injectors that alow it gas i had the same issue with my old bmw
Dec 29, 2010 | 2001 BMW 5 Series
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
My P Reg Nissan Micra wont start. It was working
Sounds like a fuel issue if you have run it dry, maybe a blocked fuel filter, or maybe it needs new spark plugs, check the air filter as well.
Nov 30, 2017 | 1996 Nissan Maxima
C280 will crank but wont start
think electrical 1st itz the weakest link-have you done a toonup-chec plug wires for wear or failure also distributer system up to 100,000 volts are used -these things fail from the heat 2nd test the fuel pump or pressure reg for gas inspect total ride for loose wires etc consider a scan 3rd
Aug 09, 2009 | 1995 Mercedes-Benz C-Class
96 Taurus just wont start
Sounds like that battery and alternator may be bad. The car will not run if the voltage is too low.Most autoparts stores will check for free....
May 09, 2009 | 1996 Ford Taurus
95 blazer VIN#W help!
try pulling put and replacing spark plugs if they are full of fuel. good luck!
Dec 29, 2008 | 1995 Chevrolet Blazer
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
99 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
