Question about Sony FD Trinitron WEGA KV-30HS420 30" TV
Clicks but crt does not turn on
The Tv clicks and CRT comes on for a second before it goes into the protection shutdown. The LED flashes 6 times and sometimes 7 times. I checked the voltage accross IC501 as suggested in other posts and one of the votages is higher thatn it should be. thesymptom for the 6 LEd flashes suggest overscurrent and bad IC 504. I don't know how to meassure the voltage on the IC504 however as it has 4 prongs instead of three. My question is if there is something that may be causing this. Please help! I can offer you the Service manual for the KV series TV in return...
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
The Tv clicks and CRT comes on for a second before it goes into the protection shutdown. The LED flashes 6 times and sometimes 7 times. I checked the voltage accross IC501 as suggested in other posts and one of the votages is higher thatn it should be. thesymptom for the 6 LEd flashes suggest overscurrent and bad IC 504. I don't know how to meassure the voltage on the IC504 however as it has 4 prongs instead of three. My question is if there is something that may be causing this. Please help! I can offer you the Service manual for the KV series TV in return... you seem to be a techanical person so answer is purely technical. Clicks but crt does not turn on 1 check whether power supply out put is ok.by disconnecting h/output 2 if it is ok check hor. section that is eht is ok or not as without eht crt will not glow. check crt supply &loose connection in crt base. regards thanks
Posted on Sep 11, 2007
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
Red LED Light Blinks 7 Times Tv Wont Turn On PLEASE HELP!
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You must have through knowledge in electronics to proceed. This is a very skilled wor. You must have all measuring instruments, and ability to follow its schematic diagram.
Jun 12, 2012 | Sony KV-36XBR400 36" TV
GE Guide Plus Gemstar. It keeps clicking when I turn it on. Clicks four to five times but never actually turns on
If a standard set (glass picture tube) you have either a problem in the main power supply or in the High Voltage circuit which is triggering shutdown as protection.
What is the model number of your TV?
May 28, 2012 | Televison & Video
Worked great for many years. Then without warning, no picture and audio stays on for 4-5 seconds; then clicks off. Unplug, turn on, and same thing happens. As if breaker switch clicks off.
if you have to unplug it to reset it, that is a shutdown protection circuit trigger. you probably have a bad h.v. transformer. (flyback)
Dec 27, 2009 | Sharp 32L-X2000 32" TV
No Power
Good Day;
Shutdown at Power Causes: Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Sep 16, 2008 | Mitsubishi WS-55807 TV
WS-55807
Good Day;
Sony FD Trinitron
In most cases when I have seen this type of fault, the CRT was getting very weak. When the emission is below a specific amount, the AKG circuits keep it biased off.
It is also possible to have defective components in the CRT bias circuits, high voltage area, and the scan amplifiers that can cause this symptom. This type of condition is more rare to cause a flashing screen as per your description.
The TV making some clicks, and the red LED flashing is an indication of the power supply going in to the protect mode. This is usually from a scan amplifier failure, or a high voltage failure, a short in one of the circuit areas, and or a defect in the power supply itself. Proper troubleshooting is required to determine the exact fault.
Jerry G.
May 12, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV SHUTDOWN
hi there, there is a power supply section problem, do some test, automatic shutdown means a power supply section problem. ty
Jan 10, 2008 | Sanyo HT32744 32" TV
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
Jan 24, 2006 | RCA F27450 27" TV
Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
308 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
