Question about McCall 4-4045 Commercial Refrigerator
Mccall 4-4045 I want to know how to convert my 4-4045 refrigerator to a freezer?
    Novelist:
  • 87 Answers
You would need to change the condensing unit (outside bit) to a larger duty, you would probably need to change the evaporator (inside coil) to match the condensing unit. You would need to install drain heater, door heaters and probably change part if not all of the control circuit. In short I would suggest not doing this unless you want to make a fridge guy a lot richer. I know fridges that can get to sub zero temps without help but I would suggest that you would be better off to buy a purpose made freezer as what would be required would probably cost as much and not look as nice. Hope this is of some help.
Posted on Sep 11, 2007
Tip
One of my refrigerators--the one with the ice maker--is outside. I only make...
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
on Jun 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
Does anyone have a davina mccall 2in1 cross trainer user manual pdf
Same problem here with no manual for Davina Cross Trainer. Lost the instruction pack during house move. Any kind soul who can scan and send to me or take a photo. I am just stress out looking at the nuts and bolts in the bag. Thanks
Jan 26, 2012 | McCall Refrigerators
What does LLL code on a Mccall 4-4070 refrigerator mean?
We have a commercial freezer and where the temp should be showing it reads LLL can anyone tell me what that means. it is a MaCall 4-4070.
thanks Lisa
Oct 20, 2010 | McCall 2-2045 Stainless Steel Commercial...
McCall freezer installed 8 yrs ago in remote area 90 miles from nearest tech. Compressor was remoted to basement. Freezer has never cooled to less than 10F--in red arc. Now won't cool less than 30F. ...
If the condenser coil is clean and the unit is in an area where the ambient temp. is 80 degrees or less, it is most likely a refrigerant problem. Probably low and has a leak. Another issue could be that the line sizes for the distance the refrigerant has to travel, may be wrong. Since I don't know the distance, you may need to have that checked into also. You should not have more than a 1-2 psi drop due to line size and distance traveled.
Sep 12, 2010 | McCall Refrigeration Commercial Freezer...
I'm looking for the wiring diagram for a McCall 4-4020C reach-in refrigerator Wiring Diagram cant find one anywhere on the net.
Hi, I have searched the Internet for the last 1/2 for any thing on McCall Commercial Reach-ins. I did however find the name side by side with Bevearage-Air, Traulsen, Denfield,True, Ect. McCall was right there. When I clicked on it, I was taken to all the other brands? I was able to get a number for you and hopefully this link may help you to get where you need to go.
www.ShortOrder.com
1-800-211-0282. I hope I have given you some direction to follow. Good Luck to you,
Shastalaker7
Jan 26, 2010 | McCall 4-4045 Commercial Refrigerator
Need to know the design superheat also normal pressures on this unit with 404A refrigerant
The McCall web site has nothing easily found on the 7-7045FT unit.
In answer to you questions, first, what is the expansion device. TXV, Cap Tube, or something else?
Low site pressure will be dictated by the super heat. The high side, in many cases, is usually ambient plus 30, then convert to psi.
Let me know if you need more info. And please double check the model number/ serial numbers.
good luck
Oct 17, 2009 | McCall Freezer 7-7045FT
Keys
Hi there!
Yes you can order a set from most locksmiths that cut keys to code.
You may be able to order a set by phone for this.
Alternatively, the manufacturer will keep replacements, but may cost slightly more.
I hope this helps you resolve this problem. If it does, Please spare a moment to rate as Fixya! Thanks.
Jun 16, 2008 | McCall Refrigerators
McCall 4-4045 Commercial Refrigerator Logo
240 people viewed this question
Top McCall Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a McCall Refrigerator Expert? Answer questions, earn points and help others
