Question about Promaster 7500DX for Canon TTL Flash
Promaster 7500dx not firing
Using a Rebel xt and xti. Doesn't matter if camera is in auto or manual, every time I use it with the flash after 4 or 5 shots all of a sudden the flash does not fire underexposing everything. Non-rechargeable batteries, the flash is fully charged, the flash indicator is also seen in the viewfinder but the flash does not fire. It is not tightened too tight so I don't know what is wrong. I have two of those flashes and both do the same thing. I never get more than 5 shots off before it does it..then I have to turn off the flash and camera..take the flash off the hotshoe (or bracket) and put it back on, power on everything and then it will work for 5 more shots..maybe just 4 and mess up again, quits firing. I contacted Promaster many times and they are not any help..I have a 580ex II and it NEVER has done this, plus a Promaster 5950 I use for my film camera works flawlessly but the 7500 DX is problem ridden..anyone got a solution?
  • 216 Answers
SOURCE: My snaps are underexposed with 350D camera and 580EX TTL
Set camera:
Single shot mode not servo/C modes
Focus sensor set for center
Make sure exp. comp is not set on -(minus) side.
Make sure your subject is locked on and not moving out of the autofocus (center) sensor.
atdlee@netzero.com
Posted on Jan 03, 2008
SOURCE: Canon SPEEDLITE 580EX - How do I replace the hotshoe mount?
These instructions are for the 550ex and I imagine that the bodies of the flash units are the same.
As with any project, make sure to get a good workspace with plenty of light where you won't drop any screws and lose them...
1) There are 4 screws on the bottom of the flash unit that you'll want to unscrew first. Carefully tilt back the bottom section away from the red filter which covers the "eye".
2) There is a set of wires going to a white harness in the piece you just tilted off which you can carefully disconnect with a small flathead screwdriver working it on either side.
3) The same type of harness attaches another set of wires but this one is just inside the body of the flash in the cavity you just opened up. This one is a bit wider and you should undo that harness in the same, careful manner.
4) Next, you have to remove the master/slave switch which is attached with two small screws that you'll need to carefully undo. The actual switch is attached to the tiny board you are unscrewing. There is a plate covering that switch that is the piece you actually push when you want to switch it. That piece will come out when you take the actual switch out so remember which direction it went.
5) Now you should have exposed four small screws as you look straight down into the piece you're working with. These screws hold on the shoe you're replacing. With some decent force against the screws, carefully unscrew them. These don't come out very easily so you want to make sure you have the right sized screwdriver that fits and that you're applying some downward force. MAKE SURE you don't strip the head on these screws.
6) Turn the whole piece so that the shoe is facing upwards. Now you can carefully pull off the shoe. Make sure to not lose the loose spring that is under this thing. You'll see that there are 5 prongs sticking up, a horizontal metal piece, and a small rod looking piece with a spring that fits over it. Take note of how these all go so you can put the new one on with those pieces in the right places.
7) Put the new piece on and screw everything back in the reverse order. Voila! You just saved yourself a bunch of money and hassle. Thanks for the tip on where to get that piece, by the way, I had been looking around for it.
Posted on Dec 27, 2008
  • 685 Answers
SOURCE: Promaster 7500dx problem
Send the flash back to Promster for repair, they are real good about fixing or replacing products.
Posted on Nov 03, 2009
  • 3 Answers
SOURCE: Promaster 7500 D Digital Flash usage with Nikon D70
you need to go to your cameras menu and set your flash function to m ( no to ttl) set it in full M and then it works hope it works that works for me i had the same problem
Posted on Oct 05, 2010
  • 3 Answers
SOURCE: Cannot get my Promaster 7500DX (for Nikon) to sync
go to your cameras menu and set your flash mode to the section of full manual and then click that, never on ttl, and set you flash also in the leter M and it will works
My Rebel XTi has what seems to be a stuck shutter button? The shutter will fire w/o the lens on but will not fire once I put my 50mm back on. I recently did a sensor cleaning. Could that have something to...
Will it fire if you take the lens off AF and set it on M? If so then your release switch may be bad - I see a lot of that. Also there is a screw that comes loose that may be shorting out the auto-focus sensor flex connector. The bottom right screw on the back circuit board always comes loose/out on XT and XTi cameras.
Aug 01, 2013 | Canon EOS Digital Rebel XTI Digital Camera
Cannot get my Promaster 7500DX (for Nikon) to sync with my D-200 Nikon camera. Can you help me ???
Jun 12, 2010 | Promaster 7500DX for Nikon TTL Flash
We have a Canon rebel XT EOS the flash pops up no matter what the
Frustrating I am sure. I had the same problem on my first XTi. I cannot remember what the settings were, but I think I was set for portrait and had flash set as the white balance default source. Therefore the camera always popped up the flash assuming that I wanted or needed fill flash.
Change you white balance to sun/shade/tungston etc as is appropriate, choose a faster ISO speed in lower light levels and try using the P or Tv mode and use a shutter speed that generates a middle range aperature for your particular lens.
Jan 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Sep 05, 2009 | Promaster 7500DX for Canon TTL Flash
I just bought the 430ex II flash and it won't fire on my Rebel XTI.... i read the manual but I'm not sure whats wrong, have any advice?
I assume that flash is turned on. 430ex flash will fire automatically only in AUTO mode. On manual modes you mus manually force the flash to fire.
If flash doesn't fire at all, consider to claim the vendor or let the vendor to check the flash mounted on your camera.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Dec 05, 2008 | Promaster 7500DX for Nikon TTL Flash
Lock disc mechanism stuck
Try to put some silicone oil to the thread the disc is turning on. The oil slowly penetrates into the gap and lets the disk rotating. Car dashboard shine sprays often contain silicone oil, check the ingredients.
Laszlo
Nov 13, 2008 | Promaster 7500DX for Canon TTL Flash
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Promaster 7500DX for Canon TTL Flash Logo
120 people viewed this question
Top Promaster Cameras Experts
teddyboy
Lawrence Oravetz
Are you a Promaster Camera Expert? Answer questions, earn points and help others
