Question about Biostar iDEQ 210M Barebone
Not Switching On
My iDEQ 210m has powered up once to the bios screen and now noting get yellow led on front but not even any movment from fans
    Novelist:
    Scholar:
  • 117 Answers
I assume you have reseated (unplugged and re-plugged) all power connectors. Try this, very carefully! Look at the power connector for the motherboard: you'll see there is a green cable (pin 14 IIRC) with a black one either side of it. Get a paper clip, straighten it and being *very* careful not to let it touch anything else, short the green cable to one of the black ones (do this with a deliberate movement - you don't want it to keep making momentary contact). The power supply should start up. If you're lucky, you'll see the BIOS screen come up; remove the paper clip (again, a quick, deliberate action). If your luck holds the power will stay on and the machine will behave normally after that. If either the BIOS screen does not appear or removing the paper clip causes the power to go off again then I'm afraid you've run out of luck and the motherboard has a fault, unfortunately not uncommon.
Posted on Oct 01, 2007
SOURCE:
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
second.
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
System dead
Hi Fr.David
You mention '..info on BIOS..'
Is your BIOS (or anything) displaying on the screen?
If screen is also dead, then your PSU 5V (red) section is suspect.
As the fans are fanning then 12V DC (yellow) is still OK.
To check your PSU, unplug & disconnect all power connector cables (note where they go, esp the M/Board supply).
Some PSU's have a green 'signal good' wire which to test must be grounded with a paper-clip etc to black.
This tells the Power Supply Unit to start up.
Black is common negative, Yellow 12V positive, Red 5V positive.
I'm positive.
I hope your test results are not too negative. ;)
Hope this helps.
Clive.
Oct 28, 2017 | Mach Speed (MSNV-939) Motherboard
There was no beeep sound heard at the beginning Delay in turn fan power supply the Power LED on the front panel of the computer doesnt light the HDD LED on the front panel of the computer doesn't...
as i always say:
intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 25 minutes then connect all of cables and try turning on your PC:
1- with battery of bios
2- without battery of bios
it should work.
(this works cause the motherboard reset it's bios and start correctly again).
Jan 13, 2011 | Biostar TF7100P-M7 Motherboard
Power on doesn't show display i power it off and a yellow light stays on , is this fixable , i have two of them with the same problem one is ideq 330p and the other one is a ideq 200n
Yellow light means no video signal is being recieved,sound like a video board issue,good luck,(if you have on board video only way to fix is m/board replacement but if you have expansion slots avalible you can add video board.
Jan 08, 2011 | Biostar iDEQ 330P (IDEQ330P) Barebone
I have a Dell Inspiron 546 running Windows Vista. When turning it on the Start button lights up, but the display very quickly goes into power saving mode. Nothing further can be done. The computer or...
Hi. Were you able to see the the DELL post screen when you turn on the computer? Take out the battery and unplugged the power adapter from your computer and to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn on the computer.
Nov 07, 2010 | Dell Inspiron 546 MT Desktop Computer
I had cleaned my precision 530 workstation. After cleaning, the compuate doesnot load the BIOS. Even the fans are not getting switched on. But the light on the motherboard glows In the front panle the LED...
please make certain your memory chips are seated into the mainboard. Also, make sure that your mainboards power cable, and your CPU's power cable (the small yellow and black one) are secured to the board. If your components are secured to the board correctly, you may have an issue with the board, CPU, or power supply. If your pc is under warranty, I suggest you contact Dell for troubleshooting.
Oct 26, 2009 | Dell Precision 530 XEON Workstation Dual...
My computer is beeping at me during startup, and will not go past the load screen.... dell b110
The POWER LED on the front of the tower should be solid Green, If Solid Amber or Flashing Amber, there is either a power or MB problem. On the back of the tower are 4 LEDs the when posting normally are all Green. If YYGG for example, then you have a memory failure. More information can be found at support.dell.com using the no post troubleshooter
Sep 24, 2009 | Dell Dimension™ B110 PC Desktop
Blinking yellow power led
check at the back of the tower you would find 4 LEDs(small lights) labeled ABCD in a row or you might have 1234 on the front panel. note the status of these LEDs when the problem occurs and check for the solution accordingly on the support.dell. website.
would also suggest to disconnect all the devices (keyboard mouse printers etc.)next time the problem occurs and then try to start the computer
May 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Biostar iDEQ 210M Barebone Logo
186 people viewed this question
Top Biostar Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
