Question about Fisher Washing Machines
Turn on ok. Press start and spin light blinking and beeping.
Turn on, all lights come on as normal. Press start and only the spin button blinks red and beeping. Nothing else happens.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Posted on Apr 16, 2009
Valet ce0890 reprogram
check light on dash is it blinking/is it on solid ? if solid check under dash for small button or toggle switch/turn key on and press button alarm should beep and dash light should start to blink/if toggle turn key on and switch toggle switch in other position and light on dash should blink good luck!
Dec 13, 2013 | Vehicle Parts & Accessories
CANDY CLD 135-86S will not boot, blinking lights two
More than likely you have a memory or video card issue.
Whenyou plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computerand why it is not booting. Most times it's a motherboard issue when youhear beeps or blinking lights continuous. Most times the problem is withthe memory or Video Card. Count the Blinking Lights or Beeps and take note oftheir pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. Maybeyou have a Static Charge Buildup. Remove the Power Cord, then Press andHold the power button for 30 seconds. After 30 seconds plug the powercord back in and hit the power button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.Maybeyour power supply is bad. Sometimes there is enough power to make thepower light or some other lights come on but not enough power to make the fanturn on or hard drive spin.
Jun 09, 2012 | Computers & Internet
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
All lights are green except the third light is red.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
My ps3 wheni go to turn it on n press the button the lite goesfrm green rite back to red n wont turn on
This fix works for some models, so if it does not work for you please tell me your model number
Look at the bottom. This is what it looks like:
SONY
PLAYSTATION 3
CECH-*** = Your model number
SONY COMPUTER ENTERTAINMENT INC.
MADE IN XXXXX
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it, it will beep
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and blink a red light.
When this happens, turn the main switch off and on then turn it on normally.
Let me know how this goes!!
P.S. It will not harm your ps3, It's testing the cooling fan.
Nov 28, 2011 | Sony Playstation 3 (PS3) Console
Red light blinks and wont stay on when push power button
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
    The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
    The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
    the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
    Press and hold the Start/Stop button while turning the dishwasher on. Release the
    Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
    Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
    Fault codes
    F00 Pots & Pans Lit
    F01 Sani Wash Lit
    F02 Normal Plus Lit
    F03 Normal Lit
    F04 Economy Lit
    F05 Rinse & Hold Lit
    F06 Pots & Pans Lit
    F07 Sani Wash Lit
    F08 Normal Plus Lit
    F09 Normal Lit Flashing
    Sep 19, 2009 | Miele G880 Dishwasher
    Malber Dryer won't start (sine-wave light flashing)
    The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
    May 30, 2009 | Malber TD800 Electric Dryer
    Washing Machines Logo
    185 people viewed this question
    Top Fisher Washing Machines Experts
    Dan Webster
    Dan Webster
    dweatherby
    Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
