Question about Dryers
My Maytag Clothes Dryer quit heating?
My Maytag Clothes Dryer (Model # LDE9606ACM) quit heating? How do I get to and change the heating element(s)?
    Problem Solver:
  • 13 Answers
Unplug the unit and take the back off.
Posted on Apr 13, 2009
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
Aug 04, 2012 | Maytag Dryers
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Apr 05, 2011 | Maytag HYE3657A Electric Dryer
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
My Maytag Dryer model DE308 takes 2 hours to dry a load of clothes. I have air flow, but after an hour, the clothes are still damp. THe dryer does not have the heat that it used to. I know that with the...
Good day,
Your right on the heating element.
If your positive the vent system to the outside is clean, then
Remove the front panel of the dryer, and inspect the blower wheel. If worn on the shaft(slipping), it needs replaced.
2. Remove the whole front panel to access the blower housing and the chute going to the lint filter. Clean as needed. (common problem).
3. If everything checks clean, then the thermostat that is mounted on top of the heating element canister is the most common problem but is only one of the thermostats.
Maytag uses a lot of air versus heat for drying. That is why it is important that part of the system is correct.
Mar 14, 2010 | Maytag Dryers
Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
Mar 30, 2009 | Maytag PYE2300AY Electric Dryer
Dryer wont heat
check your heating element with a ohm meter.
Dec 12, 2008 | Maytag Performa PAV2200
Dryers Logo
98 people viewed this question
Top Dryers Experts
