Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have two 15 inch L7 Solo-Baric Subwoofers and need an amp
What size amp and what type?
    Scholar:
  • 152 Answers
I would recommend a brand named class D amplifier.
Connect both woofers in parallel (Positive to positive, and negetive to negetive) in a sealed enclosure. Make sure you have no air leaks. By connecting them in parallel the combined impedance will be two ohms. Make sure that the amplifier you choose can handle a load with that low of a resistance. Any high end amp should do this. Buy as much power as you can, but I would say a minimum of 1000W RMS. Beware of cheaper amps advertising "peak power". This can be considered half of what the RMS power would be (1200W peak = 600W RMS approximately).
Next, Run very heavy gauge (zero guage if you can) power line directly from the battery. Protect the wire where it passes through the body with a rubber grommet or otherwise something to keep the metal from cutting into it, and PUT A FUSE IN. I cant stress that enough. Put an 80 amp fuse in line incase you have an accident. Otherwise your car could very well burn!
Want even more punch?
Back at the amp, install the largest stiffener capacitor you can afford 1 Farad or bigger. Install this in a space where it would be protected in the event of an accident (on the inside of the strut tower or somewhere above the axle). There is a whole lot of energy stored in there that you don't want unleashed on you!
If you have any other questions please ask away!
Posted on Apr 13, 2009
  • 655 Answers
Hello kswain119,
Those L7's can handle 1000 watts each, but they will operate with as little as 100 watts. So you have lots of choices. You can get a 2-channel amp and run one from each channel, a 2-channel bridgeable and run both from the bridged terminals, or a single-channel amp designed specifically for subs.
The last would be my recommendation. Dollars for watts, the 2-channel or 2-channel bridgeable is probably less expensive, but there will be more wiring and hence more opportunities for induced noise. Also, most of the subwoofer amps will really be stable at 2 ohms. Some, perhaps many of the 2-channel bridgeable, will not be stable below 4 ohms in bridged mode. And lower impedance means more power to your subs, so I'd shoot for that 2 ohm stable and run those subs with the coils in series and the subs in parallel for a final 2 ohm load. And you want something that puts out in the neighborhood of 600-1000 watts into that load.
If money is no problem, take a look at the JL Slash v2 series. At about $1,200, the v2 will put an honest 1000 watts into 2 ohms. If your budget is more modest, consider the MTX Thunder Elite 801D at about $600. It'll give you 800 watts which will still make those L7's louder than most people can stand. And if you want even cheaper, but still good, consider the Kicker 08ZX750.1 at about $500. You could go cheaper still, but it's just not right to drive those L7's with anything less than a five-hundred-dollar amp and anything less than 750 watts of power.
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
Oct 30, 2015 | Kicker Car Audio & Video
@aol.comI have a kicker zx 1500.1 amplifier and a 15 inch L7 2ohms. Is the amp too much for it?
the amplifier is never to much for the sub. If the gain on the amp is turned up to much then that will pop the sub.
Jul 30, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a kicker 15 inch L7 solo baric and the rubber piece around the plastic part of the center of the sub has come apart from the outside black ring. how can i fix this?
You can purchase a silicone sealant set, specifically for speakers. Its quite easy to use. Ebay has alot of them and they are relatively cheap.
May 03, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a 2004 toyota corolla would i have enough air space for for to l7 15in or im i better off getting 12's
you have enough air space for 1 L715 or 2 L7 12s the 12s will move more air and hold more power than 1 L7 15 inch sub
Jan 27, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Whats the best settings for a 2 ohm solo baric 15
settings are all about what amp and box u got. tell what setting your talking about.
Apr 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
936 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
