posted by jophil on Sep 11, 2007
I have a GE washer - I need to know the bowl capacity in pounds or kilograms -
Comment by jophil, posted on Sep 12, 2007
Model WIP4013 SRW
Best Solution
posted on Sep 11, 2007
Which GE model do you have ?
Comment by dovi, posted on Sep 12, 2007
It sound like you have a blocked pump.
Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it.
Bail and sponge out any water in the machine's tub before removing the pump.
Good luck !
Good luck !
Bowl capacity is 5-6 kg.
Rating Locked! (?) jophil has rated this solution as Helpful
This Problem Also Relates To:
GE Energy Star WCVH6260F Front Load Washer
GE WBSR3140DW Top Load Washer
GE WHRE5260E Top Load Washer
Bosch WFMC 3200 Front Load Washer
Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du
Bosch Logixx WFT 2806 Front Load All-in-One Washer / Dryer
Bosch Nexxt® 500 WFMC3301 Front Load Washer
Can you Help with these Washing Machines problems?
Fisher and Paykel GWL11 Top Load Washer
fisher paykel washer
My gwl11 stops at rinse cycle... Answer This...
Whirlpool Duet GHW9150P Front Load Washer
I purchase a 4 ring dryer plug...
My Whirlpool Duet has 3... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
