Question about Car Audio & Video
1999 ford taurus radio cassette player getting an error message
1999 ford taurus radio cassette player getting an error when the tape player plays it switches back and forth and then ejects and then shows an error message T.D01. when I put on my mp3 to the cassette tape adapter even with a regular tapeit happens
merle840
  • 113 Answers
SOURCE: I have a bose stereo in my 96 nissan Maxima that works poorly
there is a problem in the tape drive - possibly a bad belt- thats why the cassette adapter keeps ejecting itself- most add on xm tuners have the ability to broadcast its signal wirelessly-you press the menu button then turn the tuner to select the menu option that you want then press on the tuner control again to choose broadcast (fm signal and which channel you want to broadcast to the factory radio-try www.xmradio.com for more detailed info
Posted on Apr 16, 2008
SOURCE: MP3 Cassette Adapter Not Working
hi.....can you check if the rola ( that has teath and roling the tape ) in ur cassette adapter is actually turinig easy because whith the new cassettes if it is hard they swich the sides thinking that the tape finished if they hard try to losen them......hopfully that wil work
Posted on Aug 24, 2008
  • 19 Answers
SOURCE: jammed cassette tape in car stereo
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
Posted on Apr 28, 2009
localwonder
  • 6784 Answers
SOURCE: cd won t eject from 2006 Ford Focus mp3 player Get
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
Posted on Jun 21, 2009
Benimur
  • 6966 Answers
SOURCE: trying to install factory cd-cassette
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Posted on Oct 30, 2009
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
How do I get the cassette adapter to play CD's out of my 1999 Ford Taurus? And can you use one anyway?
The adapters have a tendency to jam in the cassette player slot. Some cautious wiggling may release it.
Jan 16, 2018 | Ford Cars & Trucks
My cassetteplayeris broke but the front panel says tape unpluged it radio won't play pluged it back in few days later tharadio came back on.going down the road it swithched from radio playing back to tape...
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Feb 15, 2011 | Car Audio & Video
I own a 1997 Ford Taurus. I am trying to use a tape to mp3 player adapter in its tape player. When I push the tape in the player, I get a "TDE3" message and the tape spits out. I tried using another tape,...
It's the tape deck there must be a tape that got caught inside and is wrapped around the capstan or the heads and the radio stays on because the switch is not activated by the deck lowering down far enough you have to take it out and clean it and look for any tape or other obstructions that would stop the mechanism from working including the belt you may need parts and a 20 year old radio there hard to find try the junk yard for a replacement but you can operate yours with the cover off if you can get it out far enough to see inside while it's on and that will help you find the problem but first bring it inside your house so you don't loose parts after cleaning with alcohol and derusting if any and a light lubricant you might be lucky see what happens I also use an adapter for my cell phone music in a 2007 bull and I also did it in an 87 bull with a cd player so I know what your talking about also make sure the adapter wire is not hanging up when pushing it in good luck also brand new replacements might be the best way to get the music you want they have auxiliary input jacks for cell phone mp3 players but try to fix yours first the learning part is priceless for the future radios you will own
Jan 04, 2018 | 1997 Ford Taurus
Cassette ejection mechanism not working
pull the player and have it repaired, sounds like the belt is no good for the tape drive loading mechanism.
Apr 13, 2009 | 1999 Ford Taurus
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Cassette player
the tape is very tight
get a pen and try to loosen up the tape
100 % is the tape not the radio
May 15, 2008 | 1999 Ford Taurus
Car Audio & Video Logo
777 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
