Question about Dryers
Drum won't turn
Kenmore 80 series electric front load dryer model # 110.62812101 dryer heats up but the drum stopped turning
  • 490 Answers
The belt or the electric motor are out
Posted on Apr 13, 2009
5 Suggested Answers
  • 156 Answers
SOURCE: Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Posted on Mar 19, 2008
  • 1122 Answers
SOURCE: I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Posted on Feb 03, 2010
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
heatman101
  • 43501 Answers
SOURCE: My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 05, 2011
Kenmore 80's series electric dryer no heat...drum
Check your breaker by turning it off and back on. Then check wiring at plug and back of dryer. You could have a bad relay switch. You can find it under the top and put the 2wires together and try it then . If it works, you know that it is the relay switch. Last but not least, it may be your element. Check it visually to see if there is a break in it or a weak spot.
Feb 27, 2013 | Dryers
I have a Kenmore 70 series large capacity front load dryer. It will heat but the drum just stopped turning. I do not believe it is the belt. You can turn the drum with your hand very easily and...
heatman101
Aug 20, 2011 | Kenmore Elite HE4 Electric Dryer
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
I have a Kenmore Electric Series 80 Dryer that the drum inside won't turn but it heats up and smells hot like something is burning. I can however turn it manually.
Remove the top and the front panel to remove the drum after you purchase a belt and teh idler pulley that Sears selles for your dryer. The pulley's bearing has froze up causing the belt to burn up and falling off
Jan 22, 2011 | Kenmore Dryers
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
Mar 18, 2008 | Dryers
Dryers Logo
205 people viewed this question
Top Dryers Experts
