Question about RCA RT2280 System
I TURN IT ON AND IT SAYS CHECK SPEAKER THEN SHUTS OFF ANY ANSWERS
I CANT MAKE THIS WORK
    Scholar:
  • 152 Answers
Have you disconnected all of the speakers and tried? Sounds like there is a short and the amp is going into protect mode.
Posted on Apr 13, 2009
I had onkyo 5.1 hometheater i cant raise the volume more than 40 how can i fix the problem ?
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
May 28, 2015 | Onkyo TXSR309 5.1 Channel Home Theater...
My screen is not working at all
tune the phone off and turn it back on
Feb 25, 2014 | ZTE Warp
Text message centre number cant save
Just remove your sim card from the phone and then try. Sometimes it works.
May 18, 2013 | LG GT540 Cell Phone
I cant seem to get my mini's clutch to work i have replaced almost everything on it and cant seem to get the clutch working ? if someone might know way this is happaning please help
What do you mean it is not working?
You can not engage it?
You can not get it to Shift while running?
Have you Bled the AIR out of the Secondary ?
Does your System have enough Fluid?
Apr 08, 2013 | Cars & Trucks
Amps turn off and cut out
You just gotta get your gains set up right. Look Up "How To Set your Gains with a Multimeter" your over powering your subs or speakers and your amplifiers cant keep up. you also have to make sure your speakers are wired to the right ohms. your amp cant handle. if your amp cant handle, for Example:1 Ohms your gonna blow your amps. ......Speakers and subs are a science too.
Dec 27, 2012 | Kicker 10DX5001 Car Amp
The standby/on button is blinking and i cant figure out how to take it out of standby. pushing the button again does not work and i cant get my disk out
iI HAVE A DVP 642, the standby/on button is blinking and i cant figure out how to take it out of standby. pushing the button again does not work and i cant get my disk out
Oct 16, 2010 | Philips DVP642 DVD Player
Trying to increase volume on car deck when doing so the amp just shuts off, then amp makes a burning popping sound and smells like something burnt up and 3 sec later amp kicks on and still works, none of...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Please check impedance on speakers as they coyld be fried as well. A thumbs up would be greatly appreciated if this answer is helpful to you
Oct 03, 2010 | Orion HCCA-D2400 Car Audio Amplifier
RCA RT2280 System Logo
182 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
