Question about Dewalt Tools & Hardware - Others
Adjustment of sharpened cutter of porter cable 653 versa plane
I have a porter cable/rockwell 653 versa plane 3'' planer. I have had the cutter sent off and sharpened. The cutter is now shorter than it was before. How do I adust the planer for the newly sharpened cutter?
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Posted on May 06, 2009
Adjustment on dewalt planer
I don't know which planer you have, but if all the planing happens on the top side of your stock then all surfaces underneath should be at the same level.
If you have a fancy planer that cuts on the bottom side, then the outfeed table should align with the cutters and the infeed table would be adjusted below that by the cut thickness (like a jointer
Mar 17, 2014 | Dewalt DW7351 Folding Table for DW735
Delta tp 305 is sniping wood at both ends , is there a solution to this problem?
With any of these portable planers, the sniping can be a problem that you can minimize. Of course you can use a board longer than you need... but more practically: 1. Take light cuts 2. Make sure your infeed and outfeed tables are at the same height and are parallel to the suface of the machine below the cutter. 3. Provide additional in-feed and out-feed support beyond the little in-feed and out-feed tables to keep your material moving consistently in the same plane from start to finish. you might use support rollers. Take care to get the whole setup adjusted all in one plane. Good luck.
Oct 16, 2012 | Delta TP300 Shopmaster 12-Inch Portable...
Where can I get a 653 Rockwell cutter head repaired?
I would suggest a local Homedepot to bring it in to.
May 02, 2011 | Garden
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
I have a Porter Cable door planer with carbide tip blade and it has a small notch from a conceiled finish nail on an old door.The blade is still good.I would like to know how I can sharpen it.
Hi, these blades are made to fine tolerances, so I would not attempt to sharpen it. But they are also double sided. Just undo with the appropriate allen wrench and flip it over. Good luck!
Nov 15, 2010 | Porter Cable 9118 #126 Porta Plane Door...
Need a new planer blade 43233
after 5 hours searching on Google and Yahoo I settled for blade 43263 which was a lot more expensive
Nov 28, 2009 | Porter Cable 9118 #126 Porta Plane Door...
Porter Cable Plane totally dead after working a minute
The power switch may be dirty. Try blow it out with air and or solvent.
Jun 23, 2009 | Porter Cable Tools & Hardware - Others
How to use Hand Power Planer?
Power planers are wonderful little devices that move work along quickly and easily when you’re working on such things as decks and remodeling jobs. Just like a manual planer, this planes or evens the wood by shaving off enough to make a uniformly flat and even surface. Think of it as a wood shaver or an effortless sanding tool. It can take a warped edge off of a door and make it functional again or it can straighten out a piece of wood so that sheetrock will go on flat. These are very handy tools for those who like to work around the house. Understand what power planers can do. You can use them to smooth the edges on all kinds of wood or to bevel (make a cut for a joint that isn’t 45 degrees) door edges. They will level framing lumber and chamfer (make a 45 degree angle in) handrails and scribe (mark or score) countertops or cabinets and taper and shape wood trim. They’re a very easy tool to use and they save a great deal of time but, as with any power tool, you do need to spend a little practice time before you use this on a real project. Know how power planers work. They have blades that are mounted on a cutter head that spins at about 20,000 rpm. The planer sits on a sole plate, also called a shoe, and the front and rear shoes can be adjusted. The difference between these shoes determines how much wood is taken off when it’s used. There is a front hand grip that adjusts the shoes and so determines the depth of the cut. A power planer can remove from a trace of wood 1/64 of an inch to 1/8 of an inch with each pass. Know how to use the power planer. As with many woodworking and power tools, the key to using this successfully lies in holding and propelling it along properly with the right amount of pressure. Pressure is the most important dynamic used. Stand in a position that you can stay in while you take a pass with the planer. If you shift your weight, you’ll shift the pressure. Set the front shoes of the planer on the wood before you turn it on. Start it up, give it a second to get up to full speed, and then push it steadily with even pressure along the wood. Keep the pressure even on the front knob and the handle so you don’t gouge the wood deeper in one place than another. Be careful to hold the pressure steady as the front shoe runs off the end of the wood. Change the blades when they start to seem dull. You don’t want to wait until they’re smoking or throwing up powder. If you sharpen or replace the blades, do them both together as they wear evenly and replacing only one would give you an uneven cut. Unplug the tool before you touch the blades. Make sure to mount them completely according to the gauge bases that come with them. These tell you exactly how to set them in the correct position. Know how to safely turn the planer off. When you shut off your planer set it down on a wooden block and wait for the cutter head to stop spinning. Every time you use this, check the mounting bolts to make sure they’re still nice and tight. Remember your safety goggles or glasses. Wood shavings can fly all over. Once you get the hang of this, you won’t ever go back to planning by hand.
Aug 27, 2008 | Sheffield Hangzhou #532606 3" Adjustable...
Tools & Hardware - Others Logo
955 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
