Question about Dryers
Ge adora dryer #dhdvh52efoww has code E61 and does not work, how can i fix it
Ge adora dryer model #dhdvh52efoww has a code e61 and does not work. how do i fix it?
  • Anonymous Mar 23, 2014
    Need free service manual
Turning off in the middle of cycle and code E62
Posted on Aug 25, 2009
I have a GE dryer and it's reading the code E61 what does that mean
For GE dryers, the E61 code indicates a problem with the wiring or the control board. The dryer is sensing the wrong voltage between the hot and neutral lines of the incoming wiring. First check your wiring/fuses/circuit breakers. If your wiring is OK, then the control board is probably faulty.
If you post a comment with the model, I may be able to point you to the appropriate parts. I hope this helps.
(note: if you have an electric dryer using 220V, you may want an electrician to check the wiring.)
Apr 25, 2015 | GE Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
Unlock my Nokia e61 please tell code
You can get the Unlock code for NOKIA E61 model Phone at
Onlinegsmunlock.com and Unlock it from network lock easily.
Oct 12, 2012 | Cell Phones
Ge Adora dryer model#DHDVH52EFOWW started making a screeching noise in the middle of a cycle and does it again if I restart it.
remove door and check horse shoe shaped plastic guides located at the top of the door that the drum rides on for wear....replace if worn
Jan 03, 2011 | GE Adora DVM1850 Microwave Oven
Error E61 appears on digital screen. dryer does
I was told it was main computer board. Ours got the code when we had power surge.. Not sure how yours happen
Nov 17, 2009 | GE DCVH515GF Gas Dryer
Dryers Logo
1,808 people viewed this question
Top Dryers Experts
