SOURCE: Error message when I try to play a cd,dvd or rip
Before we try blaming a faulty cd/dvd unit lets check out faulty Windows Media Player Software. Is Media Player up to date? Try installing iTunes set as default. That will force the cd/dvd association to iTunes. See if the player works or what the error is...If it works...Then re-open Media player make it the default again and see it what it does. or This is from the Microsoft site: Windows Media Player cannot find the file. This error message usually indicates the link from an item in Media Library to its associated digital media file is broken. Items in Media Library are links to digital media files that are stored on your computer, a network drive, a removable storage card, an Internet server, or another location. Links can be broken for one of the following reasons: * A link to a temporary file from the Internet cache (for example, a file from the Temporary Internet Files folder) was added to Media Library and that file was later deleted. * A link to a digital media file was added to Media Library and the file was later deleted. To repair a link Do one of the following: * If you deleted or moved the file, replace it to its original location. * If you moved the file, right-click the item in Media Library, click Error Details, and then enter the new location of the file. To delete a link Do one of the following: * Right-click the item in Media Library, click Error Details, and then select the Remove file from Media Library check box. * Right-click the item in Media Library, and then click Delete from Library. Good Luck, Tim
SOURCE: windows media player not working
hi,
There might be a problem with your media player. Re-install the media player again.
SOURCE: Wndows Media Player can not find file
you must uninstall both versions of media player then reboot and install version 11
to do this go to Start/control panel/add remove programs scroll down to media player and uninstall them
SOURCE: syncing with Windows Media Player
Place the music files that you want to transfer into the My Music folder of your computer - Windows will re-read them, and then you can synchronize to your device. Also, make sure the hold/lock switch is not engaged on the mp3 player - it probably isn't, but just check.
-Tha Mp3 Doctor
SOURCE: Windows Media Player cannot find the file. If you
It seems to be the error in ur registry so make ur registry clean using reginout regcleaner
I mean Windows Media Player 12, not 11 (it was mistake).
