Question about Curtis CM32020S 32" TV
Picture wnt out suddenly without any symptoms
After turning on the Cuttis Mathis model # CM32020S, approximately one minute later I heard a "pop" and immediately lost picture, completely, (black screen). Sound still works. I pulled off back cover and found a fuse that's O.K. Now What? (24 comes on tomorrow night.)
    Problem Solver:
  • 5 Answers
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!!
Posted on Apr 13, 2009
Newly replaced lamp blew under 1 minute!
when you replaced the lamp were you wearing gloves,I hope so if not that could pop it.Other then that most likley a faultly bulb.
Dec 27, 2012 | Televison & Video
I have an LG 42" plasma tv (model: 42pc1da) and I am having a major picture problem with it. Last night, while watching the television, I heard an audible "pop" and the picture started to dim. I turned the...
The sound you heard came from one of the IC's under the heat sinks. Check the fuses on the left and right print, the print with the broken fuse must be replaced.
Sep 03, 2010 | Televison & Video
19 inch curtis mathis tv
This is the closed captioning, even though it may not contain writing in the block. If you can access the main menu then you can try and turn the CC to off. Otherwise you are stuck with it.
Please rate this answer if it helped.
Feb 12, 2009 | Curtis-Mathis CM19011 TV
Loss of electrical power
replace battery and check post. Your popping sound could have been a fuseable link. check the one thats leading to the starter.
Jan 26, 2009 | 1994 Ford F350 Crew Cab
Viera TH-65PZ850U
Without investigation it is impossible to know what failed. There are a number of boards in that set where there is fairly high current used. It is possible that some components have failed.
The Panasonic service rep would service the set by swapping out the failed modules. If the set is an older model the modules may no longer be available. You can take the set in for an estimate to see if the parts are available, and to see if the set is worth to service.
Jerry G.
Jan 17, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Lost color on curtis-mathis tv
CHECK FOR AND REDO LOOSE SOLDER JOINTS
Nov 20, 2008 | Curtis-Mathis Televison & Video
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Curtis CM32020S 32" TV Logo
225 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
