Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
Too hot Foods and liquids seem to overheat very quickly. Usually within 15-20 seconds things seem to boil over or explode. Recently something was left in the oven for excessively long causing it to really burn. The odor lasted a few days, but now it just seems to overheat.
    Scholar:
  • 192 Answers
I wish my m/wave was this powerful. try reduceing the time 1200 watts is a lot of power. may your used to a lower powered modal
Posted on Apr 13, 2009
Why don't you want the cover on when you cook
You can't put a completely sealed container in a microwave as it would explode. Other than that, there's no reason you can't cover what your cooking with something - a lid, plastic wrap, etc. Some foods will get mushy when covered, so you have to be selective about what types of foods you cover.
Jun 25, 2016 | Microwave Ovens
MH6701XX
it is toast,replace unit
Apr 18, 2017 | Maytag Microwave Ovens
Microwave shuts off within 3 seconds of start, all 00000's, restart, same thing, sounds like computer lost its memory within 3 seconds of starting. the numbers flashes before it shuts down
This problem is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in GE's bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
One way to test it is to do the following:
NOISY MAGNETRON TEST (c) 2009 and posted by William E. Miller prototech@usa.net (permission granted to FixYa to keep this on their site in this post)
(I the poster am the copyright holder on this and hereby grant permission to this site keep this on this site)
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. )If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.)
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions
here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help
here. I'd recommend that your bookmark this link to your favorites.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find links to helpful exploded view diagrams and part ordering help here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Dec 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
At least twice in the past month have had food explode all over the microwave (as if it was overheating). Items vented properly or not covered at all. this time, kept making poppong noises for at lesat 10...
If you have an item overheating, try looking at the directions on the unit for the watts and adjust cooking time according to the oven. Some foods will explode if left for too long in a quick heating microwave oven. If this is a new problem and the microwave is 4 years old, you may consider the unit is beyond its useful life. Its difficult to tell w/o knowing the brand, but it could be the meagtron tube is simply wearing/worn out. Let me know if this helps. m
Oct 20, 2009 | Sharp R-428J 1200 Watts Microwave Oven
GE Microwave turns itself off after a few seconds
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, I would suspect a "noisy" failing magnetron.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
6. Shut the door.
NOTE:
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Jul 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE JVM1860 shuts off after 1 second when using any cook cycle
Sadly, we hear of this over and over.
Thisis due to a defective or loose magnetron causing electricalinterference and disruption in the control circuit board.
Ifyour magnetron was recently replaced, it may have loose mounting nutsor bolts or maybe the wire mesh RF gasket was not installed or gotpinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Ifyou or someone you know decide to look into it, we have criticalinformation on safety, disassembly and door switches at our site, andour link is at our listing here on FixYa.
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting.
Ifit's within the magnetron portion of the warranty (usually 5-9 years)but out of the original full warranty (usually 1 year), then yourmanufacturer will cover the part cost, but not the cost to visit you orthe labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Oct 15, 2008 | GE JVM1860 Microwave Oven
JVM 2070 shuts off
My unit does the same thing - it will often simply power down or power down and display garbage on the control panel within a second or two of starting operation.  I have found in my case this seems related to slight obstruction preventing the exhaust hood from pivoting to the open position at the top of the unit.  Mechanical misalignment of the pivoting fan panel seems to cause a motor overdraw, or something similar, which shuts down the unit.  I've found that I can usually slide the pivoting fan panel a mm or so to the right or left, usually right (oddly), and then the panel will swivel unimpeded and the microwave will work.  As my unit has cabinets above it, I believe that over time there has been sufficient physical contact/impact with the pivoting exhaust panel to slightly deform it, affecting its ability to freely rotate down from the vertical.
Sep 24, 2008 | GE JVM2070 Microwave Oven
Slow Heating
Water is always called for in standard microwave heating tests.
By design, water molecules are what are targeted by the microwave cooking process.
If your line voltage is correct and it is slow to heat, then almost certainly your magnetron is failing.
If it's within the magnetron portion of the warranty but out of the original full warranty, then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 23, 2008 | Maytag MMV5186A Microwave Oven
Kenmore microwave shuts off after several seconds
Hopefully the hood / vent fan was always on when boiling on the stove top.
Otherwise moisture can get into and damage the keypad or control circuit board.
That may be the problem.
If this is a convection model, it may have a bad thermistor (not to be confused with a thermostat).
The full model has three more digits, in case you need more help and want to post that.
If you or a friend decide to look into it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find an exploded view by entering your full model number here: http://www3.sears.com (the 3 is correct)
Dec 06, 2007 | Microwave Ovens
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
144 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
