Question about Hotpoint Aquarius WF000 Front Load Washer
Door will not open on my auarius extra
The door will not open on my hotpoint aquarius extra.it was an ex hire machine.somebody said it may be set to lock after a set amount of time, can anybody help
  • kimmimac Oct 27, 2008
    Came in this afternoon and found my machine with the red light on final spin, considering I had put the load on before I left for work this morning I was not expecting to see this, anyway I went to open the door, nothing, switched it to the off position expecting it to click but nothing, put it on a short spin, it still didn't work. HELP!
    Kim
  • 209 Answers
I am a recently retired engineer and this sounds like a damaged interlock, its possible that it is faulty and the contacts inside have fused shut, make sure the power is switched off and unplugged for a while and try again first, make sure the cycle has also finished and the machine is empty, etc, to open the door if its still stuck remove the lid and move the clip from behind, you may find that the machine may not work after this, if so replace the interlock with a new one. work safe remove plug, if this has helped please rate me thank you
Posted on Sep 11, 2007
SOURCE:
Hotpoint aquarius extra wma40 - door locked light is flashing and want lock. also before this happened a sound from the machine like an explosion which blew out fuse in the house. please advice
Hi.
I suspect that the top control board has blown , this happens when the brushes wear out in the motor, and short circuit the motor armature, which in turn blows the control board.
Either way it is likely to be an expensive repair, my advice to you would be to buy a new washer if it is more than 5 years old.
I know from experience that this is the most likely course.
Nov 13, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 28, 2009 | Washing Machines
Hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Module panel
These are available from EMW electronics who sell reconditioned modules at around half the new price.
Check their website for more details.
Hope this helps.
Thankyou for using Fixya.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Nov 03, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
94 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
