Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
Power is on. Broiler ignites. Oven does not ignite. How long before the igniter goes bad?
Whirlpool Freestanding gas range made for Kirkland Signature.Model #SGS375HQ The Broiler works fine. The oven stopped igniting; it worked yesterday. It doesn't work today. How long before the igniters go bad on these units? I bought it May 1999.
3 Suggested Answers
meztang
  • 112 Answers
SOURCE: stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
SOURCE: whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Posted on Nov 20, 2010
Kirkland sgs375hq
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Mar 20, 2014 | Whirlpool Ovens
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The broiler and the burners all light but the oven doesn't.
your oven igniter is no good. remove racks from oven, unscrew the 2 screws in the back of he bottom panel. remove panel. there will be a metal plate on top of the flame spreader. remove the wing nut holding the plate and remove plate. you should now see the igniter. now try turning the oven on. after a few seconds you should see the igniter glowing. if it gets to a real bright then it is good. if it doesnt it is bad. unplug the stove.changing it is fairly simple. just remove the 2 screws holding it in place, gently pull on the wire to see if there is a connector, if not then you can always cut and join the wires to install the new igniter. igniter should run you less that $20 bucks. its pretty simple to change. after changing the igniter and before reassembling your oven, just plug it back in and turn the oven on. oven should lite. do not put hands or ace inside the oven while attemping to lite.
Feb 02, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Bake feature on oven won't work ignition light glows but flame won't spark. broiler works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 10, 2010 | GE 30 In Freestanding Gas Range ...
Oven will not ignite because the gas is not coming out.
not a good way to light the oven . so do ck for the loose connection . as cooking will be much easer.. if gas ck the ignitor and if elect ck the connections on range pig tail ( power cord ).. mm hope t this helps...
Jul 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Stove top ignitors do not ignite but oven does.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
BROILER WORKS, BUT OVEN BURNER DOES NOT LIGHT Model SF362LXSQ
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
ggdh
Feb 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Gas oven igniter glows, but oven does not turn on.
That is correct. You will have to check if the valve needs replacement or if there is power being sent to the solenoid for the valve. There must be just a connection problem.
Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
201 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
