Question about Soltek SL-75FRV Motherboard
CPU Upgrade I have the soltek SL-75FRV Socket A Motherboard and my original processor was the AMD Athlon XP 2000+ with Throughbred core and FSB 266MHZ. I'm trying to find out the fastest cpu I can upgrade to without having to update bios. I recently upgraded to a AMD Athlon XP 3000+ with Barton core and FSB 333MHZ which the board supports but the bios needed updating as it didn't display the correct speed when booting up. It was displaying 2800+ not 3000+. And yes, CPU clock and actual processor speed was correct in CMOS setup utility and jumper setting on board was set to 166MHZ, so it just needed an update. Unfortunately the update failed so I'm looking to upgrade to another cpu that doesn't require a bios update and will display correctly. Does anyone know if an update is needed when upgrading to any barton core cpu and if so, if I stick with the thoroughbred core will I still need to update bios if I go for a faster thoroughbred cpu, even if FSB is either 266MHZ or 333MHZ.
    Problem Solver:
  • 6 Answers
Re: CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (
Posted on Sep 11, 2007
0 characters
3 Points
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
What is the upgrade cpu for this motherboard
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU;
Never flashed a bios? Instruction are listed on ECS web site.
Jun 13, 2010 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Upgrade my processor
You can use either an Athlon, Duron, or Athlon XP processor, with a max front side bus speed of 266 MHz. This is slow compared to today's standards. Most of today's newer processors have front side bus speeds of more than 2 GHz, about 8 times faster.
May 10, 2008 | Intel Motherboard
EliteGroup K7S5A (does not say pro on the board)
According to their website, the board can take:
AMD Athlon XP (Throughbred up to XP2600+)
AMD Athlon (including Thunderbird)
AMD Duron (including Morgan)
You can then overclock the processor with a BIOS upgrade available at
It has one 4X AGP slot so it can take any AGP video card, assuming the card is backwards compatible (8x -> 4x).
Jan 13, 2008 | EliteGroup K7S5A Pro Motherboard
Processor - Supports Socket-A AMD processors (Athlon/Duron)
- Supports FSB 200/266/333MHz
Rate me SOLVED
Nov 23, 2007 | Soltek SL-75FRV Motherboard
Hi, I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties. To upgrade the BIOS: 1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown; 2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 28, 2007 | Soltek SL-75FRV Motherboard
Looking for the best/fastest processor for this board,47.html try this link!
Apr 06, 2007 | Syntax SV266AD Motherboard
Soltek SL-75FRV Motherboard Logo
413 people viewed this question
Top Soltek Motherboards Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Steven Wander
Steven Wander
Are you a Soltek Motherboard Expert? Answer questions, earn points and help others
