Question about GPS
What is tfd50w46?
I have 11 "tfd50w46" and want to know: What is it? How can I hook it up?
Had the car towed and the left a tow hook stitching out the front bumper how do I remove it
unscrew the hook and keep it in the car incase it has to be towed again. There is a place in the car for the hook, I don't know where but it is in owners manual
Feb 03, 2013 | 1999 Volvo S80
I would like to ask anyone who has experiment on hook up....
Do you have necessary cables to hook up balanced output? its 3 pin cable.
Please let me know to help you further.
Sep 21, 2008 | SMProAudio SM Pro Audio TB202 2 Channel...
Trying to hook up a new cd player to my truck but dont know wat wires to hook up there note coded or had a plug do you know the colors to hook one up
bestbuy sells a harness that directly plugs into your truck. Or ebay search smart harness then go to car electronics and they are there, prewired.
Sep 19, 2011 | Car Audio & Video
I must be hooking ipod up wrong dont know where
You should have a cable that goes from your ipod to a USB connection. Then you just plug the USB connection into your computer, then the other end into your IPOD
Aug 29, 2009 | Apple iPod nano
The usb do not work at all. ibm t42 23731WU many thanks !
If none of the usb ports are recognizing anything you hook up to them then that means the motherboard is bad. Easiest way to know, hook up a usb mouse or usb keyboard, those it should detect and install.
If it can't do that then you know for sure the motherboard is bad. If it does detect the keyboard and mouse then you know its the other devices that your hooking up that are faulty.
Aug 21, 2009 | IBM ThinkPad T42 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
DVD hook up
You need 3 pins cable for Components Video hook up and 2 pins for Audio Right-Left conncetion.
There is another option of Yellow-Red-White combination for Video / Audio hook up.
Please let me know what type of set up you need.
Aug 22, 2008 | Insignia LCDTV26 26 in. Television
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
GPS Logo
76 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
