Question about Euro-Pro Steam Generator EP8001 Iron
Euro-ProX EP8001 steam cleaner with iron
My Euro-ProX cleaner/iron also referred to as model EP965 works fine except that the steam cannot get out of the water holding tank.
  • 1 more comment
  • skipalong Sep 11, 2007
    I already have the plan, just need a response. Why am I not trying to be helped?
  • skipalong Sep 19, 2007
    Yes, I still need a solution. none has been offered so far. When Can I expect a comment on this???
  • Anonymous Mar 13, 2008
    When trying to operate the iron, the steam does not work. Unable to get the steam to work on the iron.
4 Suggested Answers
SOURCE:
SOURCE: Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
tombowdb
Now for Sears to try to locate the tool that will open the case.
Posted on May 20, 2008
haider_alhar
  • 90 Answers
SOURCE: Steam escaping from water tank with EP8001 iron
your thermostats should be changed
Posted on May 30, 2009
SOURCE: Euro Pro Steam Generator EP8001 Iron - manual needed
call euro pro at 7-800-798-7398
Posted on Mar 01, 2011
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Euro-pro ep8001 steam iron
I found the fix myself.
I found a switch without the light and it works
Sep 08, 2008 | Euro-Pro Steam Generator EP8001 Iron
Europro steam cleaner with iron
Hello Margoi,
Unfortunatly I can not help you with instruction, but from user reviews I know that it has exactly 1 liter capacity.
regards,
Konstantin
Aug 06, 2008 | Euro-Pro Steam Generator EP8001 Iron
Contacted Shark customer service and they emailed one. My product was the EP 8000 which is no longer produced. Sent the revised manual that is only a bit different for the EP 8001. Call them, they are very nice.
Jun 19, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
tombowdb
Apr 17, 2008 | Euro-Pro Steam Generator EP8001 Iron
EP8001 Steam generator.
Sears sells a screwdriver set (47486 is written on the handle) that has a lot of non-standard drivers. There is one on there that will fit the nuts on this unit.
Also, I used a rubber tube from an Auto parts store to replace the cracked hose. I figured the Automotive hosing was designed to withstand the heat of an engine. So, it should work on this iron.
Bring the cracked iron hose with you to the auto parts store.
Oct 07, 2007 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
394 people viewed this question
Top Euro-Pro Irons Experts
Bruce Showalter
Sheldon Dedek
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
