Question about LG Prada KE850 Cellular Phone
Unable to make or recieve calls
When trying to call out the number is excepted and then the phone terminates the call. Also can not recieve calls, when ringing the phone a constant tone is heard. Checked the SIM card in anothewr phone all ok. All other functions of the phone are fine including text. Hope you can help Thanks Mincemeat
Have a look your security setting under settings menu and go into the call barring section to click cancel all. try it and hope it can help!
Posted on Sep 23, 2007
SOURCE:
Unable to make calls or send sms messqges
It can be the settings issue.Click the link below to reset :----http://technoanswers.blogspot.in/2012/02/unable-to-make-calls-or-send-sms.html
--------Thanks.
Feb 13, 2012 | Cell Phones
When I get an incoming call it doesn't appear on the external screen until the call has ended so I can't see before answering who is calling me. And the screen with the number that's calling me and the...
When I try to delete my calls from the call log, there's a pop up that says uncaught exception and when I recieve a call the number does not show on the external screen until the call has ended and stays permantly on the screen....How do I fix these problems
Apr 15, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
No dial tone. Cannot call/recieve.
Have you tried placing the handsets in the base unit to resync them? (not the axillary charger)
Have you confirmed that the phone jack and wire are still working? (e.g. plug in a known-good corded phone and make sure the signal is still good)
Post back with the "Add comment" button on the right, and we'll see what we can do to get it fixed.
Jan 20, 2010 | Uniden 5.8GHz Cordless Phone
How do I enter and prefix a phone number with the + sign
  1. press the star button twice for + nd then input ur number
  2. another option is all the incoming calls are folowwed by a + sign.. so go to ny recieved call and go to edit number or use number option.. then delete the rest of number except the + sign
Aug 17, 2009 | Samsung X640 Cellular Phone
Unable to send or recieve calls and texts. It is not the sim card
try using a different sim in your set to confirm whether it is a set problem or sim problem. If it is a set problem, restore the factory settings.
Jun 20, 2009 | LG TRAX Cellular Phone
I cant recieve or make phone calls or text messages
I am facing a similar problem in my blackberry. everything looks fine except incoming and outcoming calls. can someone provide a solution for this....
Jan 14, 2009 | RIM BlackBerry Pearl 8100
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
LG Prada KE850 Cellular Phone Logo
143 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
