Question about Olympus FE-210 Digital Camera
Master Reset Olympus x840
My cam olympus x840 is "crazy" and I need to reset to default factory settings. I can't do anything because the buttons don't respond. Please I need help.
    President:
  • 919 Answers
To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
Posted on Apr 13, 2009
How do i reset Olympus X940 to factory settings
Hi how to hard reset my camera olympus x-940
Feb 20, 2012 | Olympus X940 Digital Camera
The camera only takes black/blank pictures. I have no LCD screen. I am a novice, and this is my first SLR camera. I purchased it used off of Ebay, the previous owner swears that it worked when he sent...
Turn your camera off, remove your batteries for about 30 seconds and let it reset to default. Then try inserting the batteries and see if this helps. a link to go to is: www.olympus.com, then select americas, then select support, then select your camera, then download your manual in PDF format.
there is firmware built-in software which the camera uses to work properly. As a software, you can update it by connecting the camera to a PC and running the Olympus Master software that should have been included with the camera.
Then Set (PC MODE) in the E-300's (Set up Menu) to (Storage). If the operating system is Windows XP, remove the memory card before connecting the E-300 to the PC.
In the Olympus Master software Help Menu, you can look for "update firmware" to follow the instructions. Good luck
But be forewarned that it will only work if you have the newest Olympus Master Software Update, Olympus Master 2. Olympus Master 1.1 will not be able to connect with the online server. Luckily, Olympus Master 2 is a quick and free download from the Olympus site.
Otherwise this could be an intermittent shutter problem or speed setting going astray?
Look like it may be a trip to the Olympus Repair shop
Try to set all menu items to default as much as you can. Some cameras have a reset to default setting or a button to reset to default.
After setting to default, try the camera again.
If all fails, this camera will need repairs.
If it is too old, and not worth it, it may be the best to sell for parts on a site such as Ebay.
  • Dec 25, 2010 | Olympus EVOLT E-300 (Double Lens Kit)...
    770SW Olympus needs a factory reset, lens stuck open
    Contact Olympus for the factory reset code.
    Sep 01, 2017 | Cameras
    Blurry images on camera
    When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
    Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
    http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
    Apr 22, 2009 | Olympus FE-340 Digital Camera
    Olympus FE-310
    The reset option is located when you hit the Menu button when in shooting mode - it is on the left hand side of the screen. You would click Reset and press Ok. It will show Reset Yes or No. Select Yes and press Ok. The camera will now be in factory default settings.
    Jan 15, 2009 | Olympus FE-310 Digital Camera
    Olympus FE-140 ok except that flash does not work
    Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
    Dec 28, 2008 | Olympus FE-140 Digital Camera
    Need to factory reset E-Volt 500 Digital Olympus Camera
    Put camera dial on P - go to Menu - camera 1 tab is highlighted - right arrow over to card setup - down arrow to custom reset setting - right arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera should now be in factory default settings
    Dec 24, 2008 | Olympus EVOLT E-500 Digital Camera
    E-volt 500 Olympus camera will not work well on most settings.
    Turn the camera mode dial to P - press Menu button - camera 1 tab is highlighted - right arrow over to Card Setup - down arrow to custom reset setting - right arrow to reset and press Ok - highlight Yes and press Ok. The camera should be back in factory defaults.
    Dec 23, 2008 | Olympus Cameras
    I need to reset my olympus e-520 to its default settings and i don't know how.
    dear airwin433,
    to reset your caamera to default setting follows the steps.
    1. press menubutton(which is the second button from down in left side of your camera )
    2. screenpops up in view fiender.
    3. select the custom reset option.
    4. there select th reset option ond press ok button.
    and now your camera is resetted to default settings.
    Sep 22, 2008 | Olympus Cameras
    E520, fn button can not be set to "face detect", and can not reset to factory settings
    In Auto mode this is true. If you turn the camera dial to P you will be able to reset the camera to factory settings and set the fN button to be face detect. In Auto the camera is already using the factory default settings for the camera.
    Aug 16, 2008 | Olympus Cameras
    Olympus FE-210 Digital Camera Logo
    942 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
