Question about JVC Audio Players & Recorders
I need new drive belts. - JVC Audio Players & Recorders
  • 104 Answers
**** smith electronics i bought a ten pack of assorted belts yesterday for $ 7.97 good luck
Posted on May 24, 2009
HAVE NEW ALTERNATOR,NEW WATER PUMP,NEW RADIATOR,NEW THERMOSTAT HOUSING ! YOU HAVE TO DRIVE IT TO 30-40mph THEN NOISE STARTS BUT WHEN COME TO A COMPLETE STOP THE NOISE SLOWLY QUITS BEFORE I CAN OPEN THE...
If the noise sounds like a whistle or squeal, it may be the accessory drive belt slipping. You stated you replaced the alternator and the water pump, but did you replace the belt? Belts may look good even as they age, but they dry out and will get a glazed appearance and this acts like ice on the pulleys. The different accessories (alternator, power steering, A/C. possibly water pump) all provide resistance to the belt as it attempts to turn them. The faster the car runs, the more resistance. Thus, at idle, there may be no noise, but at 40mph, the resistance on one of the pulleys may get so great that the glazed belt starts slipping, causing a noise. This slippage could also be due to a belt that is not properly tight. If your vehicle has an automatic belt tensioner, it could be in need of replacement. If it is manually adjusted, it may need to be readjusted. Be advised, though, re-tightening a glazed belt may make the noise go away, but over-tensioning a drive belt can cause belt breakage or bearing damage to the drive accessories. It is worth the cost of a new belt to not have to replace all the drive accessories.
Mar 16, 2015 | Cars & Trucks
Rockworth 1.5 hp 6ltr oil free compressor drive belt replacement
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Feb 19, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Replace drive belt Bosch pbs7a
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
Johndeere gx75 drive belt diagram
I broke a drive belt on my gx75 and need to know proper routing and installation for new one AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
Jun 15, 2012 | Cars & Trucks
Hi I need a new serpentine belt put on my 1999 alero however I do not know how many grids the belt is supposed to have can you help me please
drive belt has 6 ribs.to buy a new belt take old drive belt with you you so you will get the right size belt.tell the auto parts store the year and model type car.tell them your engine size.and they will find the belt size you need.
Apr 25, 2011 | 1999 Oldsmobile Alero
Severe vibration in 96 sportsman 500. New belt,
Could be a few things. First I would check your drive belt to see if it's worn, if its good then could be two other things, Drive clutch bushings sticking or Excessive clearance between belt and sheave, you can fix by with a new beltadjust the clearance bychanging the number of shims.Also if your drive belt is less than 1 1/8 inch wide you probably need a new one. Hope this helped.
Mar 17, 2010 | Polaris ATV
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Stiff turning
you could be low on pwer steering fluid. CV joints won't affect steering. That is for powering the wheels.
Very important. Make sure shop did not overtighten a/c belt. If they did, you could be in danger of breaking your crankshaft snout. It may be a good idea to check that.
Also, did they tighten the power steering belt correctly?
Did this steering issue sstart after repairs
go here for help
http://autos.groups.yahoo.com/group/villagerquest/
  1. The tension for the water pump and power steering drive belt should measure 603-691 N (135-155 lbs) for a new drive belt, 495-583 N (110-130 lbs) for a used drive belt. The limit for drive belt tension is 196 N (44 lbs).
    1. Adjust the water pump and power steering drive belt tension as follows:
    2. Raise and support the vehicle.
    3. Remove the RH front fender splash shield (16102).
    4. Loosen the water pump and power steering pump drive belt idler pulley locknut.
    5. Tighten the drive belt tension by turning the water pump and power steering pump drive belt idler pulley adjustment bolt counterclockwise.
      1. Tighten the water pump and power steering pump drive belt idler pulley locknut to 33-37 Nm (24-28 lb-ft).
      1. Install the RH front fender splash shield.
      Deflection Adjustment
      1. NOTE: If the drive belt has been in service for some time, it should be inspected before adjustment. A drive belt that is severely glazed, frayed, cracked, or contaminated with oil must be replaced. Minor cracks in the back of the drive belt are acceptable as long as no large pieces are missing.
        Apply 98 N (22 lbs) of pressure to the drive belt at a point midway between the power steering pump pulley and the water pump pulley.
        1. NOTE: Always check the drive belt deflection when the engine is cold, or has been stopped for at least 30 minutes. A drive belt is considered new if it has been used on a running engine for less than five minutes.
          The drive belt deflection should measure 8-10mm (0.31-0.39 inch) for a new drive belt or 10-12mm (0.39-0.47 inch) for a used drive belt . The limit of deflection is 16.0mm (0.63 inch).
        1. If the drive belt deflection is not as specified, adjust the water pump and power steering pump drive belt tension. Refer to the procedure in this section.
  1. The tension for the A/C compressor drive belt should measure 603-691 N (135-155 lbs) for a new drive belt or 495-583 N (110-130 lbs) for a used drive belt. The lower limit for drive belt tension is 196 N (44 lbs).
    1. Adjust the A/C compressor drive belt tension as follows:
    2. Loosen the A/C compressor drive belt idler pulley tensioner bolt.
    3. Tighten the A/C compressor drive belt idler pulley adjustment bolt.
May 25, 2009 | 1995 Mercury Villager
2002 XG350 - Do I need new timing and drive belts?
timing belt and most drive belts are good for 70,000miles, i think the mechanic trying to take you for a ride, as for the drive belts inspect them if there is any cracking ware marks etc replace them but seriously if they look like new which they should with only that many miles would not need replacing.
May 14, 2009 | 2004 Hyundai XG350
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
118 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
