Question about Philips E-Box FTR9965 DTV Receiver
Philips E-Box FTR9965 Blinking Red Standby Light
Switched the E-Box on and instead of the standy light going green all it does now is flash/blink red. any ideas? The Philips plasma TV will not operate now - although if I connect my PC to the screen it works fine so there is no problem with the screen.
  • 1 more comment
  • tsiappas Jan 25, 2008
    the same
  • Anonymous Feb 08, 2008
    I am experiencing the same problem as described above. What type of pc is solved the problem? What type of pc do you recommend, to resolve the problem?
  • Anonymous Mar 31, 2014
    red light was on turn it off wont turn back on
Mine was the same, took it to comet, fixed it within a week and gave me a warranty. Thirty pounds call out fee and another forty five pounds when they bought it back fixed, highly recommended, not like the idiots at philips who couldn't be bothered
Posted on Mar 18, 2008
    Problem Solver:
  • 6 Answers
Hi, my TV is starting to develope a problem & I have traced it to the e box (mine is FTR9964). I had the screen repaired in January (would'nt start from cold) cost was £156 inc vat. Anyway this time its the ebox & since we are going digital next year I thought I would try & do away with the e box by using one of these http://www.js-technology.com/product_info.php?cPath=22&products_id=33&osCsid=c05e56ff6e909a4b42d53af48a5940ae I managed to buy one on eBay for £30, so fingers crossed it should be problem solved. Allan
Posted on Oct 01, 2007
SOURCE:
KDF-60XBR950 Red light blinks 5 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 01, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Philips 29pt828c/25 crt tv won't turn on, the red standby light is constantly flashing. Have unplugged and left for days and then switched on it powers up, get picture and sound and then say 4mins later it...
The flashing light indicates a fault. These flashes are called blinking codes. Count the number of blinks occur at one time switch ON. Counting of blinks to Philips is not done directly. It is a sort of coded. If you wish to get more details, check the site linked here. Counting procedure to Philips TVs is given in detail. Please keep some time with the instructions. It will be somewhat seem difficult to anybody who doesn't know anything electronics. http://electronicshelponline.blogspot.com/
Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 15, 2013 | Televison & Video
After turning on the tv the green light comes on then it clicks back to blinking red after a few seconds
Issue with Logic Board Fail to innitial Voltage Safety Control Swich due to fails component inside TV Set... Please Refer To Certified TV Shop Repair ...
Oct 09, 2010 | Philips E-Box FTR9965 DTV Receiver
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Phillips FTR9965 / 12s
The no signal message is there because the screen is waiting for a signal from the receiver, it then switches into protection mode (flashing red). The usual cause is a blown protection fuse inside the receiver.
May 27, 2008 | Philips E-Box FTR9965 DTV Receiver
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Monitor shutting off with blinking standby light.
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Dec 14, 2006 | NEC PlasmaSync 50MP1 50 in. Television
Philips E-Box FTR9965 DTV Receiver Logo
632 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
