Question about Konica Minolta DiMAGE E50 Digital Camera
Hoizontal lines in images
My camera is 2 years old. 6 months ago horizontal lines began appearing in all pictures, particularly those in bright light. I've reformatted the SD card twice; once on the computer and once on the camera. Neither solved the problem. Can anyone help?
    Champion:
  • 206 Answers
The problem is faulty CCD sensor ( this device converts light into image ) so faulty sensor means either poor quality pics or no pics at all. Have sensor replaced and camera will work fine.
Posted on Sep 11, 2007
    Problem Solver:
  • 10 Answers
"My camera is 2 years old. 6 months ago horizontal lines began appearing in all pictures" The problem is not the sensor as the first solution has been posted, the real problem is connected with the flat cable inside lenses that is broken. You cannot replace it, you can raplace intere zoom. The problem is frequently on this type of camera and direct connected with camera frequent use. The fixed and automatic diaphragm do not work bacause broken flet is broken and the sensor is receiving too mach light. Take the camera, switch it on then light with a flashlight the lens, you see a diaphragm movement or hear a click on the lens, if not the flat wire is broken (means microcut inside flat invisible without a magnifying glass). Most time same problem is present with no image on the screen because diaphragm is completelly closed.
Posted on Nov 08, 2009
SOURCE:
My Z1275 has developed intermittent horizontal lines on the view screen when the camera is moved, and on images some times. Get good images if I use tripod and shutter delay. Looks like loose connecti
When having bright lights on a dark background, you can have horizontal lines. That is supposed to be normal. but the camera should give good pictures in bright light. Try setting the camera in automatic. most of the time it is the green camera loge on the mail dial.
Jul 21, 2014 | Kodak EasyShare Cameras
We are getting hoizpntal lines on all photos taken, but in video mode, it looks normal. Doesn't sound like lens to me?
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Nov 07, 2009 | Canon PowerShot A95 Digital Camera
Darkened image
same for you, please red this: "My camera is 2 years old. 6 months ago horizontal lines began appearing in all pictures" The problem is not the sensor as the first solution has been posted, the real problem is connected with the flat cable inside lenses that is broken. You cannot replace it, you can raplace intere zoom. The problem is frequently on this type of camera and direct connected with camera frequent use. The fixed and automatic diaphragm do not work bacause broken flet is broken and the sensor is receiving too mach light. Take the camera, switch it on then light with a flashlight the lens, you see a diaphragm movement or hear a click on the lens, if not the flat wire is broken (means microcut inside flat invisible without a magnifying glass). Most time same problem is present with no image on the screen because diaphragm is completelly closed.
Oct 23, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Horizontal Lines throughout the images
That Canon Expert is not giving ur correct info i have done huindreds like this it is 100% CCD Fault and it do have a CCD unit installed either he is not a tech or he is trying something on u , pls dis regard his advice and kindly see below just call canon
CCD FAULT has various SYPTOMS like
Over Exposed Daylight pics indoors ok but extra light is a problem
might be puikish redish or purple tones
Streaks noise or complete Black or Blank pics
dont waste time just call canon
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 28, 2009 | Canon PowerShot A430 Digital Camera
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Too bright picture with white lines in them
I suggest you to write a letter to Canon and to contact your local service dealer. After some struggling, they accepted the warranty claim and repaired my camera free of charge. The problem appeared when the camera was 23 months old.
Aug 24, 2008 | Canon PowerShot A430 Digital Camera
My friend, I believe that that is a CCD issue. The horizonal lines and the interrmitent issues with the images are all related to a CCD issue that was notorious on the S-series camera.
Why the tech told you there is no CCD is beyond me, but all cameras either have a CCD or a form of the CCD and this is most likely causing you the issue.
eBay is a very good spot to find replacement parts!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Images with white horizontal lines
Send it back to sony, It has recall for this problem, Ck web site.( Sensor chip is bad )
Jun 11, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Konica Minolta DiMAGE E50 Digital Camera Logo
252 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
