Question about Samsung S85 Digital Camera
S85 Samsung turns on but screen stays black
I can turn the camera on - the lens opens and extends but the screen stays black. I can view the photos that are on the camera but it won't let me take any - the batteries are new.
    President:
  • 1,223 Answers
Actually u are a victim of BAD CCD see this link below
http://www.imaging-resource.com/badccds.html
but good news is all brands are doing this free of charge repairs sony, fuji, canon , olympus all, some models have service advisories issued and some are not noticed as all do not complain so u can get it repaired free even if u are out of warranty and even if ur camera is not on service advisory list tell them abt BAD CCD and they will understand and take ur repairs free of charge do not accept any charges for repairs as it is the manufacturing fault of CCD units tell them u know about it !
pls dont waste time see the service centre in ur area and email or give them a call see the link below for support in ur area
www.samsung.com
PLS RATE ME FIXYA for help if u like
Posted on Apr 13, 2009
  • Shoaib Rais
    Shoaib Rais May 29, 2009
    kindly update ur rating these ratings affect our rankings
    i hope u got help in ur problem
    Pls rate me WELL ! i am here to help
    Regards
    Zohail
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
Will not display even there is power
When you turn on the camera and the lens extends, there is a small protective shutter on the outside of the lens that should open. Turn the camea around and look into the lens. Did the protective shutter open?
If not, give it a little nudge. Sometimes they can stick. If it doesn't open, or if it does/is open and there is still nothing on the display, then there is probably a more serious problem internally.
Hope this helps
Randy
Dec 01, 2012 | Canon Power Shot SX210 IS Digital Photo...
Samsung S85 camera wont turn on. When the power button is pressed the green light flashes and the camera beeps three times than turns off. how do i fix it?
I quote the solution posted for another expert about this same problem...
My daughter has a Samsung S850, and returned from a weekend trip last night. She pressed the "Power" button and the blue light next to the button came on, as did the screen. The camera then gave a "buzzy beep" three times and shut-down. She decided the batteries were low and replaced them with ordinary AAA alkaline batteries, nothing special, and got the same result.
This morning I checked the voltage on the new and old batteries with a volt-ohm meter and found the old ones were low but the new ones were good.
I read this site and saw a comment that the camera worked after the lens was worked a little bit.
Upon a close look at the lens, I could see tiny grains of sand around the outside of the glass, so I got a wooden toothpick and gently worked the sand out with plenty of tapping on a solid surface to drop them from the area. I also worked the tip of a clean toothpick under what appears to be a soft rubber sealing ring on the outer surface of the glass.
After all this, when the "Power" button was pushed, the lens moved out and the screen lighted, and all the camera now seems to be working.
I should add that shortly after my daughter bought the camera, she lost some kind of metal or plastic ring from around the lens, and that left the "works" around the lens open to view: I can see two tiny screws the lens that are probably ordinarily covered.
Is the lens supposed to be covered by a curtain when power is off? From what I see, the lens is always uncovered. Maybe that lost ring held something else!
Its possible that
it needs repaired by samsung; You can follow the below link for tech support - http://www.samsung.com/uk/info/contactus.html
Hope this helps; send us you test comments.
Feb 26, 2011 | Samsung S85 Digital Camera
My kids accidentally dropped my Panazonic Lumix TZ-10 on the floor (not from a great height). The lens at that moment could only half close, but after turning power on and off a few times, now it opens and...
The warranty is unlikely to cover accidental damage but you could check if you have any insurance cover, perhaps in house contents or travel, or you might ask the retailer if he would help under 'goodwill'. It sounds as if the lens extension mechanism was pushed out of kilter and cannot now complete its opening cycle so...as a last resort...you could try taking out and replacing the card or gently waggling the extended lens to see if this could help. Hope you can get it working again!
Dec 26, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Problem with camara
Lens isn't working and need to be replaced.
Jun 07, 2008 | Cameras
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Hung up
check the power supply section for faults. If you need any spare parts,we can help.
Nov 26, 2006 | Sony Cyber-Shot DSC-S85 Digital Camera
Samsung S85 Digital Camera Logo
239 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
