Question about IBM Netfinity 5500 M20 4RY (86624RY) Server
Bios upgrade error
Hi, After i upgrade bios on IBM Netfinity 5500 M20 i cannot start my server.Screen does'nt appear and i have beeps in this order: 3 beeps 3 beeps 2 beeps How to recover from this?
  • 625 Answers
Re-install the old bios. evidently the new flash bios is not compatible with your machine.
Posted on Sep 11, 2007
SOURCE:
At bootup, I receive a message about a problem
Turn the computer off.
Remove the RAM from that J1/Slot6 slot.
Reconnect the power and start it.
Do you still get the "problem" message?
Mar 26, 2010 | IBM Netfinity 5500 M20 4RY (86624RY)...
Netfinity 550
Hi
The error message you are receiving "Inquiry command failed Using IBM-PC ServerRaid Host adapter" makes me think you are attaching the tape drive to the ServerRaid Controller, which is only for Hard Disks. There should be a normal SCSI interface for attaching tape drives, etc. It's possible that the ServerRaid card is a PCI (or older) plug in card, and the normal SCSI interface will be on the main motherboard. If you look on the IBM website for the Hardware Maintenance Manual, it should hopefully make things clearer.
The reason you may not be seeing the hard drives in CMOS, is because you will need to use the IBM ServerRaid Utility to view and configure the disks.
Jun 01, 2009 | IBM Netfinity 5500 M20 4RY (86624RY)...
Missing support/installation cd
I had the same problem.
There is a cd that came with the server called "IBM RAID Support" that is a must have to reconfigure the hard drives.
It took me a week to find the ISO image.
I will upload the cd via FTP and send you the link.
Apr 07, 2009 | IBM Netfinity 5500 M20 4RY (86624RY)...
CauseWay error 03
Causeway errors are due to memory issues 95% of the time.
Check this link out and see if it helps you narrow it down:
http://donaldkenney.110mb.com/CAUSEWAY.HTM
Dec 23, 2008 | IBM Netfinity 5500 M20 4RY (86624RY)...
Network & Speed Problem
I suspect that the network interface card failed, & that's why you get the error message. Try disabling it from the BIOS & see if the error message disappears. If it did, then you have a failing network interface card & need to install anew one.
Jul 22, 2008 | IBM Netfinity 3500 M20 8657 Server
Keeps on rebooting
The processor fan should have failed. check it out.
Feb 17, 2008 | IBM Netfinity 3500 M20 8657 Server
Running Non-ECC Ram in a IBM Netfinity 3500 M20
Dear NickB,
In my experience working with many servers, Non-ECC memory will not work on a machine that requires ECC memory. It is possible in some servers to disable the ECC mode in the system BIOS to allow non-ECC memory to work, but you will often end up with performence problems later on.
Hope this information helps, let me know if I can be of any further assistance.
Oct 31, 2007 | IBM Netfinity 3500 M20 8657 Server
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
IBM Netfinity 5600 8664 81Y Server
The disk that comes with the machine is called the NOS in the manual. It is also known as ServerGuide 6.0.3 which will config your Netfinity up to Win2000 Server. I used ServerGuide 7.3.06 to install Windows 2003 Server. The latest version (IBM ServerGuide Setup and Installation CD v7.4.17) is on the support IBM web site:
http://tinyurl.com/5fmv5k
Sep 21, 2007 | IBM Netfinity 5600 8664 Server
Video controller disabling
That model server comes with onboard video. If you wish to use a PCI video card then all you have to do is place it in the server and the BIOS will automatically disable the onboard. If it currently has a PCI video card in it, just remove the PCI card and you should get the onboard video again. Hope this helps.
Aug 28, 2007 | IBM Netfinity 3500 M20 8657 Server
IBM Netfinity 5500 M20 4RY (86624RY) Server Logo
459 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
