Question about Home
My refridgerator is not cold and how can i fix it
  • 659 Answers
You have posted this under bathtubs/whirlpools. Try reposting under the refridgerator forum. Have a great week.
Posted on Apr 13, 2009
Refridgerator problem wont; stay cold freezer is cooling down
Bad condenser. Leak in the line, low coolant. Bad compressor. Or the cheapest fix the thermostat.
Aug 06, 2014 | Kenmore Refrigerators
Freezer keeps frezzing with ice and the refrigerator is not keeping cool
I'm not a refridgerator repairman but when coils get covered with ice it is usally because the refridgerant (freon) is low. You will need a liscened repairman to fix it. If you try to do it yourself, you will be calling a repairman anyway and it will cost way more to fix it then to have repaired.
Nov 20, 2012 | Kenmore Refrigerators
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Air conditioner isn't blowing cold air
Could be a number of things...electrical connections causing the compressor not to run. Turn on AC and turn your thermostat all the way to cool...now visually check to see if compressor is engaged and not just free wheeling. Most likely you lost your refridgerant due to leak in the system...would need to find leak and repair then have your system re-charged with refridgerant. Best case scenario...your system just needs a charge of refridgerant due to not having enough.
Jul 25, 2009 | 1993 Mercedes-Benz E-Class
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
My refridgerator runs but does not stay cold.
First you can try cleaning out all the dirt, dust and debris from around the compressor. Second try to recharge the freon in the unit. Third you can probably have the compressor tested it may be weak and neeb of replacement. In most cases it's cheaper to replace the refridgerator............
May 06, 2009 | GE Refrigerators
Marvel beverage refridgerator is not staying cold anymore
Make sure you have 3-5" of space all around, otherwise it keeps sucking its own hot air and reaches 'equilibrium' and won't get any colder. Ever
Jan 15, 2009 | Refrigerators
Ice maker not working
Please fix the rating..
Jun 03, 2008 | Refrigerators
Home Logo
46 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
