Question about Nokia E61 Smartphone
Screen fading slowy and then reset
Sometimes when I just receive a call the phone freezes and when I look at the display the picture is slowly fading from the edges to the center and suddenly dissapear like the phone is turned off. After 2 seconds I see something like a bootup-screen with Nokia logo(but without to hands shaking and any sound) and then the phone back up running without entering PIN-code. The phone reset in some strange way??? This happens 1-2 times a week, and YES, it has happened even with fully charged batteries.
  • johnwhite247 May 18, 2009
    Similar, when I get a call it will reset the phone about a minute in, blank screen then reboot. I have swapped batteries and E61s so if it is a software problem I have backed it up and restored it on to the new phone.
    President:
  • 1,223 Answers
It is a software problem it seems like just hard reset ur device like this if it doesnt help then pls update ur System Rom from www.nokia.com
downlaod the software update utility from nokia and then connect the in ternet and update ur ROM thru cable supplied with phone u will get all software for backup and drivers from the nokia website
pls first hard reset like this if it helps PLS RATE ME FIXYA for help !
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
if it doesnt work then try this to hard reset
switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
pls let me know of the results and do rsate me well if i helped u
Posted on Apr 13, 2009
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
Sound no picture
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 17, 2012 | Televison & Video
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
Samsung Tocco touch screen freezes
i've got the same problem with you. my phone wont respond to my commands everytime i charge my phone. sometimes it responds but would respond very slowly as if the interface is lagging. every now and then the phone would freeze and wont respond and wont turn off and only way to turn it off is by removing the battery. anyone else having similar problem? how to fix this?
Aug 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Phone freezes..turnswhite..not work.
After buying my KRAZR, spending $300 on it, plus service, plus memory card, ring tones...etc....it started doing the same thing. It will be fine, but go to white screen still rings etc just no display. Took it to cell company purchased it from and they couldn't do anything with it, even still having the warranty from motorola, couldn't be sent to them for repair....irrepairable damage....WATER DAMAGE....Just charge it, leave it off, and get what you can off of it b4 it blanks again...mine is still the same after a year. Longer left off, better chances of coming on.
Jul 12, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
There is a Fading strip of white Running across my screen
try resetting your phone factory setting it will help.
Jul 02, 2009 | Nokia E63 Cell Phone
The display on my old Pioneer stereo multi CD receiver fades
The problem is a bad solder connection probably on the display itself. These are not the easiest to open up. I would not suggest you attempt this if you haven't done these before. This is a simple fix for any shop that handles audio repair. Call around for a shop that works on Pioneer gear and request an estimate over the phone. Indicate that the dispaly has bad connections that need to be resoldered. You may find a shop that will repair this for short money. Where are you located? Perhaps I can suggest a shop.
Dan
Jan 14, 2009 | Pioneer Audio Players & Recorders
My t-mobile wing screen is blank
If you are still able to recieve calls but the display is blank means its not a phone problem but rather a display problem. The LCD display panel is damaged and needs to be replaced. If the phone is still under warranty then rush to the nearest service center and they should fix it for free. Otherwise the panel costs around 100-150$. You can replace it on your own though..
Dec 02, 2008 | Samsung Blackjack SGH-I607 Smartphone
Nokia 6030 screen fading
only slightly damaged lcd screens can take affect once there is a litle crack heat builds up on the screen and you have to repair it
Apr 02, 2008 | Nokia 6030 Cellular Phone
Nokia 6630 display problem
restore ur handset and try else fone requires a service frm nokia care.
Nov 09, 2007 | Nokia 6630 Cellular Phone
Nokia E61 Smartphone Logo
154 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
