Freezers
Problem for Freezers
Generic problem for all Freezers
Replacement thermostat in chest freezer
By sunbeam on Sep 11, 2007
Help please I need to replace the thermostatin a Zanussi ZCF 164 chest freezer . The eletrical end is straight forward, but the sender end of the capillary tube disappears into the back of the freezer. How do you get at this, do you have to empty the contents and access it from the inside?
Thanks,
Peter.
Comments:
Sep 11, 2007
- Thanks, I have just had a quick look and assume that the evaporator plate must be inside the inner casing and accessable only with the unit empty of all frozen food and the lining removed in some way.
Same Problem
May 13, 2009
-   looking for a new thermostat for my walk in freezer... can anyone help?? model: Let0901F 500 watts 230 volts serial # 94C02 -   Guest
Aug 07, 2008
-   I have a 6 ft Elba (EF660) chest freezer occasionally with the ventilation fan in the compressor compartment runing but the compressor not running and with the clicking sound coming from the thermal cutoff. With my thermostat set to the minimum coldness (no 1 of 10 division) I am getting - 23 degree C . Notice that the thermostat dial can not go smoothly to 0 , it was kind of tight when I force it to 0 and getting a click sound , that will cause the compressor to shut down.
When the freezer fan running and compressor not on, I will normally switch off from the mains and switch it back on again after an hour or so. Then it will be running fine until it start to play up again.
On occasion when it is working fine at min. setting of 1 coldness, when it normally auto off apparently when it reach it set coldness , I turn the dial up to max. coldness of 10 , the compressor just doesnt come in . Am I correct to assume that the thermostat is not in working order (maybe in permanent max coldness) , stressing up my compressor and causing the occasional failure of the compressor to cut in due to the overheating causing the thermal overload protection to intervene .
Dont mind to replace the thermostat, how to go about it ? The sensing probe go into a copper tube into the freezer as I can see from the compressor compartment, trying to pull it out but it is not coming out , is it secured by a clip inside and how do I get access to it ?
Will appreciate if any one can advice . Thank you .-   steyep
Best Solution
posted on Sep 11, 2007
Very Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1079 votes
in order for the "stat" to sense the coldness of the freezer box it needs to be within the chilled space. it is probably held on by a couple of clips on the underside of the freezer compartment on the evaporator plate.
Comments:
Sep 11, 2007
- I tried to look at the UK site for electrolux zanussi freezer. I'll bet once you empty out your freezer that the cappillary is in the bottom in some kind of shroud. the evaporator plate is all along the bottom of the freezer
Was this helpful?
Yes
No
Popular Solutions for Freezers
Questions and Unsolved Problems for Freezers
Answer
I'm looking for an upright frost free freezer in white with between 16 and 20 cu ft and temperature... (More)
Answer
How to tighten handle on Woods Upright Freezer model V17NAB
Answer
freezer first started to warm up from the bottom up. then it stopped cooling all together. i changed... (More)
Answer
i have thermador kburt3661a01 fridge icemaker not making ice @ was dirty last time it made
Answer
Our 12 yr. old jenn air refridgerator freezer ice maker has not shut off twice and ran all over our... (More)
Describe your Freezers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Freezer Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
