Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
John deer where is the oil filter on a 1967 john deer tractor 3020
  • 1 more comment
  • Anonymous Mar 28, 2014
    JOHN DEER L118
  • Anonymous Mar 31, 2014
    Haven a schwartz front end do I need a adaptor plate to bolt it to my 3020?
    I want to change my narrow front to a wide front using a schwart front I bought can I use bolts from narrow front to bolt to frame also do I need a adaptor plate.
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
Posted on May 05, 2009
Torque specs for the intake and exhaust manifold bolts 3020 gas
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
1964 john deere 3020 WORKSHOP SERVICE REPAIR MANUAL
Jan 08, 2016 | John Deere 3020 Gas & Diesel Tractor...
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
Ran out gas 3020 now will not start
try squriting some stating fluid in it the carb it should start if does look for water are dirty gas replace it with clean gas fresh gas dont use old gas chang fuel filter changs hydrostatand filter and oil do a service on it use a fuel additve called`sea foam in only one that i no that works follow instruction on bottle how to use see if that wont get you going
Sep 03, 2014 | John Deere Step 2510 2520 3010 3020 4000...
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Where's the hydraulic oil fill for a John Deere 3020? Is it next the seat? What's the hydraulic system oil capacity? What type hydraulic oill would you suggest?
The oil fill cap is just above the oil dipstick at rear of tractor.
the capacity of the system is 4.5 gallons.
Oct 08, 2010 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
377 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
