Question about HP DeskJet 610c InkJet Printer
Paper it just keeps drawing paper though the printer antil ther is nothing left some times drawing 2 or 3 at a time
    New Friend:
Two adult friends of don't get along together and started up draming behind each others backs what do i do to help the other one out.
Posted on Oct 16, 2014
  • 625 Answers
Sounds like a software problem. re-install your printer drivers. as far as drawing more than one sheet, it is usually a humidity problem or the pages are just "stuck" together. when you load any paper into the printer, "fluff" up the stack before putting into the hopper
Posted on Sep 11, 2007
Konica Minolta c250 duble sided alignment. Can i print same alignment with this printer?
Mam/Sir,
Did you match the proper paper with the machine paper weight on print driver must match the draw and the paper weight on the paper package such as Thick 1, 2, 3 and the weight on the paper package g/m2. use copier spec page to determine Thickness. also try running it though once for one side then second time requires no duplex re-running a second time from same draw. But a tech coming out to look at the machine might know if you have a registration problem on double side copies, he might also have a firmware update he can install the correct the problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 10, 2016 | Konica Minolta Office Equipment & Supplies
Printer will not print from any computer and keeps saying that A4 paper is not available even though full
a4 is metric for 81/2 x11. check your printer properties ensure they match what the copier thinks it has in the paper draws, also check control panel printer properites mite be that a4 is default
Jan 28, 2014 | Konica Minolta Bizhub C364 Color Copier /...
Error code c-0204
remove draw #2 remove the paper behind it. also do not store paper on the left side of the draw. its not a storage area its for 11 x 17 paper.
Jan 22, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Printer keeps saying there is no paper even though there is. It pulls the paper through but prints nothing on it. The screen flashes E 0 2... help!
The travel of paper through the machine is timed and if the pickup roller is no longer as tacky as it should be, the paper may be arriving too late to allow for printing. Cheap 'copier' paper has a soft surface which can lose fibers over time that can cause the pickup rollers to have less grip on the paper too.
There is also the possibility of remnants of paper (or more often labels) that can delay the timely arrival or may be impeding the progress of the sheet through the paper path.
May 14, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6A00 comes up. Data line and power cord
That error means the purge assembly is not working properly. Could be a scrap of paper stopping it from cycling properly. The purge unit is the cleaning assembly where the printhead parks, it has caps that draw ink from the printhead to clean and a squeegee to wipe off the excess ink. If the printhead comes to the center, unplug printer and check on the right. If nothing there you probably need a shop repair.
Feb 15, 2010 | Canon PIXMA MX850 multifunction InkJet...
I have a piece of paper jammed in the inside of the printer.
It insists there is a Cartridge problem on the Printer............  In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer............ Now Try to Print.......... Good Luck..............
Jan 21, 2009 | Lexmark X5470 All-In-One InkJet Printer
Hello I have a canon lbp2900 which has been functioning well. When I try to print i get a message asking me to insert a toner cartridge, however there is a toner cartridge in the machine and I am sure that...
I just posted the similar problem recently. After talking to canon printer service tech, this is what solved my problem:
1. open the top cover and remove the cartridge
2. Inside the printer, these is black roller (with sponge&soft material). Press this gently couple of times
3. below this roller, there is a gray roller. press this roller upward couple to times gently
4. insert the cartridge and try to get print out
hope that helps.
May 12, 2008 | Canon Office Equipment & Supplies
Paper feeder
clean the rubber roller with alcohol this roller gets dirty all the time...this feeds the paper...im trying to upload my drawing..to guide you..
Feb 09, 2008 | Canon S520 InkJet Photo Printer
Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Oct 03, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP DeskJet 610c InkJet Printer Logo
Clive
Clive
