Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Old Garmin 300 that takes forever to get reception
I have an old Garmin 300 that takes forever to get a reception in flat terrain in good weather. What is the best solution to speed up the process? Software downloads, hardware fixes..?
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Apr 19, 2010
TV reception breaking up pretty bad because of rainy weather here in Brooklyn New York I live in an apartment and I'm using a Winegard amplified antenna does anyone have any suggestions what improving...
Television signals are at such high frequencoies they will be reflected form buildings and other objects, and attentuated by moisture in the air and through the leqaves of trees, etc. In large cities yourt TV singals can arrive from different paths Digital TV signals bounce as di the old "analog TV" signals but the technology allows the receiver to ignor singals that are out of phase so the picture is "clean" despite multipleversions of the signal arriving at the antenna at slightly different times. That said, if the signal is weak, there is little you can do other than experimanet with positioning the receivng antenna. Typically, building walls attentuate televisoin signals so locating the receving antenna close to a window often provides for stronger signal reception.
Amplified antennas cannot amplify what is not there. Moisture in the form of fog, rain and snow will attenuate television signals and if thre signals are marginal in good weather, they may be virtually not-existent in wet weather. Digital TV signals are threshold dependent. When they are toow eak, you won't see anything. Back in the old analog TV days, you could see a "snowy picture" but digital TV doesn't allow for that. The signal is either strong enough to be viewed or it is not.
You have few real options if you do not subscribe to cable or a satellite tv provider. Amplified antennas can help but if you need them you live in a marginal TV reception area to begin with and more prone to the vagaries of weather and the seasons.
Jan 18, 2015 | Winegard FL5500A FlatWave Amped Indoor...
We have a Phillips flat screen tv with an outside digital antenna. We get great reception of certain stations and then poor fuzzy reception on occasion of others that all come out of the same general...
You are in somewhat of a fringe area and subject to the vagaries of proper reception. Hopefully you have a good outdoor antenna mounted as high up as possible. You might also consider adding an antenna amp to the downlead to boost up the signal.
Digital signals are not as strong or robust as analog ones and good reception can be thwarted by tree leaves in the path of the signal to your set!!!!!!!!! You should have as clear a line of sight to the transmitter as possible. Relocation of antenna is also another possibility.
Jun 12, 2017 | Televison & Video
Cant get weather on my motorola MH370CR
Setting the Weather Channel
Your should radio receives weather frequencies if you are close enough to a reporting station:
1. After turning weather reception on, press . The current
Turning Weather Channel Reception On and Off
1. To turn weather reception on, press and hold + (plus) for three
seconds.
2. To turn off, press + or turn the radio off and then back on.
Your radio receives weather frequencies:
1. After turning weather reception on, press MENU . The current
channel flashes.
2. Press + or - to select the appropriate channel with good
reception in your area.
3. Press PTT to save the weather channel setting.
Here's a link to the MH user guide.
Best regards.
http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
Feb 02, 2014 | Motorola Radio Communications
I have a 2011 GMC Terrain (1 month old) and the trunk will not open
With a vehicle that new I would not tamper with it
you may void warranty.
go back to the dealer
you payed good money for your car so get good service
Feb 07, 2011 | 2011 GMC Terrain
I have weird noise when i hit the starter my car only has 67 ,000 it is a 300 with a 3.5
WE CARNT HELP UNLESS WE NO WHAT TYPE OF NOISE IT MAKES as there are so many types of quear sounds when starting a car weather 20 years old or like yours 2 y/old SO whats it sound like
More info needed. Ron
Oct 16, 2009 | 2007 Chrysler 300 AWD Sedan
The battery couldn't even sustain 5 miles. Please help.
If your bike has not been used for a long time or you have continuously charged this battery since you bought it the battery is most likely no good anymore. it sounds like the battery is no good. Especially if when you bought it it could run for much more time if the battery is old replace it and only charge the new one when needed and for the specified amount of time. Like your car, batteries do not last forever and this type of battery is under much more load. Batteries plus will fix you up with the correct battery
Sep 30, 2009 | Electric eZip Trailz 26 Women's Comfort...
The gps looses satellite reception. Repositioning
DIY is risky in this situation, besides there is 3 months warranty by Garmin on their interventions I would suggest you get it done by the professionals
Jul 18, 2009 | Garmin Quest GPS Receiver
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
GPS Logo
79 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
