Question about IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor
IBM E54 15 in.CRT
High brightness problem
Ello,hope this thing coud help.Have you already replaced your
FBT? is your screen control from the flyback working well, if not-
chage your FBT.
Posted on Dec 17, 2007
E74 set 100% still too dark to see photos
A veteran IBM. Open the case and try to locate a sub-brightness knob and carefully "add" more power. And the end is not so far, I am afraid.
Apr 01, 2014 | IBM E74 17" CRT Monitor
Problem with IBM E74, a really old one, constant brightness. I changed he brightness and contrast. but it still looks, when we increase the brightness you know. its somewhat , only somewhat better when i...
if you increase them from the line in the board and the problem still you must exchange the line with another indeed its still in the market
if you not you must go to the line and deal with them
Nov 27, 2010 | IBM E74 17" CRT Monitor
Sir iave an IBM desktop and the monitor windows
Press Fn+F5 to decrease brigtness Fn+F6 to increase brightness
Try this please.
Jul 05, 2010 | IBM E74 17" CRT Monitor
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from or from or from --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Monitor problem
Hi ,
you set the Brightness manually or otherwise you will repair the monitor.
Aug 15, 2009 | IBM E54 15" CRT Monitor
There are re-trace lines across the CRT.
check the G2 ,if to high retrace lines wil be vissable.If ok check the RGB,12V on picturetube panel.
Are the lines in one collor then check the circuit of theat collor
Jul 27, 2009 | Televison & Video
T20 screen Is there a brightness setting.
There is a Bios setting, it isn't hidden though. Config > Display > Brightness (high/normal).
Try that.
Jul 02, 2009 | IBM ThinkPad T20 2647 Notebook
Monitor Menu Poping up again & again
1. First U can change Microswitches on front pannle (Menu,select,+,-)
2.check dry points in MICOM&EEPROM IC,HV IC and It's related.
3.check 5V supply and replace 5V Regulator.
Oct 05, 2008 | IBM E74 17" CRT Monitor
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor Logo
101 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
