Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Cannot set clock on DMR-EH75V DVD player? - Panasonic DMR-EZ47V DVD Recorder/VCR
  • 87 Answers
On this model you must hook-up a antenna or cable to ant input and start with first time setup and wait 24 hrs with the power off for it to gather guide information. I Have a setup guide or go to Panasonics website at www.panasonic.com/dvdhelp/ you must also connect the video out to video in on your tv.
Posted on Apr 13, 2009
  • 20 Answers
The automatic time setting from a cable or satellite provider may no longer be available to you. It was previously provided by TVGOS by embedding a time signal in the analog RF signal of participating channels. Unfortunately the TVGOS service was discontinued several years ago when analog broadcasting ended.
To set the Date and Time manually using the remote control while stopped:
Press [FUNCTIONS]
Press Up or Down Arrow to select "Other Functions" then press [ENTER]
Press Up or Down Arrow to select "Setup" then press [ENTER]
Press Up or Down Arrow to select "Setup" then press Right Arrow
Press Up or Down Arrow to select "Clock Settings" then press [ENTER]
Press Up or Down Arrow to select "Set Clock Manually" then press [ENTER]
Press Right or Left Arrow to select the Date and Time digits, Time Zone, and Daylight Savings Time (DST).
Press Up or Down Arrow to change to the digit, Time Zone, and DST settings.
Repeat for each Date and Time digit, and Time Zone.
When done, Press [ENTER] to start the DVR clock at the chosen date/time - preferably synchronized when the minute changes in the time displayed from your cable or satellite provider for best accuracy.
Press [RETURN], then [FUNCTIONS], then [FUNCTIONS] again to leave the setup menus.
The time may drift slowly and lose accuracy in a week or two, so it may be necessary to repeat the above procedure periodically for best accuracy.
The Daylight Savings Time rules have changed since this DVR was manufactured, so I recommend setting DST to OFF and adjusting the time manually when needed.
Posted on Jul 03, 2017
Panasonic DMR-EH75V DVD recorder time shows when OFF, but unit won't turn ON.
Do a hard reset first and then check. If it do not help, it's main system control memory ic will be faulty. Contact any service technician to get this set repaired. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 28, 2017 | Panasonic DMR-EH75V - DVD recorder / VCR...
How do I stop my Panasonic DMR-EH75V DVD Recorder from automatically turnig itself off after 75 seconds?
It could be overheating.. Is it fairly consistent at 75 seconds? To test put the unit in the fridge for 30 minutes then quickly connect it up and test. If it is longer then 75 seconds then something is getting to hot. I've put hard drives (especially laptop ones) in the freezer if I need to copy off data but it clicks/stops working at room temp.
Aug 10, 2014 | Panasonic Diga DMR-EH75V DVD...
Trying to set time manually on Panasonic DDR-eh75v
The Panas usually have a menu option for this. Are you saying you can't find the menu, or it's not working when you get to the menu?
Aug 27, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can my Analog reciver Panasonic DMR-EH 75 v be converted to a digital reciever
I bought a set-top converter box from Dish Network, which will operate with the DMR-EH75V through the remote control cable that was provided with the recorder. It tunes in all the available digital channels and uses the RCA A/V cables to connect to IN1 on the back of the recorder. TVGOS is now provided through channel 2.1 (CBS) in our area and it also provides the time signal that keeps the recorder's clock updated. NOTE: ONLY the Dish Network boxes work with these functions. I've had occasional issues with the box after some period - a few weeks - it needs to be rebooted or reset to manual and then back to automatic (which causes it to reboot anyway.) Model no is DTV PAL PLUS.
Jan 06, 2011 | Panasonic Diga DMR-EH75V DVD...
Dvd in set2 mode cannot clear panasonic diga model
If unit display set2 (the number that display set1, set2, or set3), hold down 2 and enter button at the same time while unit is on for more than 6 second.
Sep 05, 2009 | Panasonic Diga DMR-EH75V DVD...
Can the panasonic dmr-eh75v copy a vhs tape to DVD?
Yes, that's mostly what I use mine for. You actually copy your VHS to the Hard Drive, then copy from your hard drive to your blank DVD. I'm about 1/3 of my way through reformatting my VHS library (800+ tapes.)
Nov 25, 2008 | Panasonic Diga DMR-EH75V DVD...
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
Unlock Regional Codes
panasonic modelo dmr-eh75v mi aparato tiene un codigo que no puedo entrar set 3 y no se como desbloquearlo para que trabaje el control remoto
May 08, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
243 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
