Question about Avanti W789SA Top Load Washer
Drain hose cracked and leaks water
Drain hose has an opening and when the washer drains the water leaks.
  • Anonymous Apr 24, 2009
    I orderd the hose and received it. Should I hire a repair person or can I do this myself.
  • arletski Mar 24, 2014
    I have the exact same problem How did you remove the old one? Did you do it yourself?
    President:
  • 1,294 Answers
You just have to replace it. Try these sites for spares with your model number, etc:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 13, 2009
LG WM2075CW seems to leak AFTER a load is finished. Wtare found front left under washer and also in the drawers of the pedestal. Anyones best guess?
(1) If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
(2) Check the tub seal for tears or cracks.
(3) Check the door boot seal for condition.
(4) Also check the tub-to-pump drain hose for cracks or tears.
(5) Lastly, check the drain hose for condition.
Replace whichever offending part that is found to be defective.
Mar 01, 2015 | LG Washing Machines
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water is all over the floor from the washing machine. What could be the problem
water pump, hose or tub.. depends when you noticed water. After it was filled? during draining or filling? Also a clogged drain will cause backwash. Holes in tub from rust will leak out water, water pump cracked can leak water or hoses to drain or to washer not sealed or cracked. Overfill from a faulty fill valve can also do that, but then you'd see lots of water all obver on that one.
Jun 16, 2010 | LG WM1814CW Front Load Washer
Water Everywhere
Look for loose, cracked, pinched, broken hoses to and from the water pump or leaks from the water pump itself. The outer drum could have a rust-through that leaks. This can be repaired with epoxy, but the inner drum must be removed to access it. The cabinet top is opened by using a putty knife or similar tool to push straight back under each front corner which releases a spring latch. Sometimes, the drain hose outlet is pushed from the house drain by high water flow. Tie the hose to the drain with tape or cord. Fill the tub with water, then stop the cycle and watch for leaks.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
Water leaking during drain and spin
Hi!
You Need to check the following--
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Rylee
Apr 03, 2009 | GE Washing Machines
Machine is leaking when filling with water Under the lid there are the following number 24422300 and CS0256934
If machine is leaking check all connectors on the drain hose make sure their tight and also check for cracks. If you find nothing externaly then its internal and need to open the washer and check the hoses for lose connections or cracks on the drum and water pump.
When you do this be sure to have it unplugged and drained of water!!
and follow basic eletrical saftey!!
Hope this info helps to anyone who reads it.
Feb 25, 2009 | Kenmore 22422 Top Load Washer
My GE WCSE4160B2WW top load washer is leaking.
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker
thanks.
Nov 05, 2008 | GE WWSE5240D Top Load Washer
Maytag Performa Washer
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Avanti W789SA Top Load Washer Logo
183 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
