Question about Frigidaire PLES389D Electric Kitchen Range
The glass top on my Frigidaire Electric Range Drop-in/slide-in model PLES389DCB has come loose. I am able to life the glass up and can see the grey/silver colored glue has failed. Where and what kind of glue do I buy to reglue the glass?
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
SOURCE: I am looking to replace
Super! It may be a while before I can get to this project but with this kind of installation instruction in hand I am quite confident it is something that I can do myself and will therefore now go forward with the purchase of that main glass top. Thanks again!
Posted on May 12, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 70 Answers
SOURCE: Frigidaire glass top range
yes u can.unplug the unit from power.remove the screws under neath the glass top at the from and lift the top up,hold it up using a piece of stick like u hold bonnet of car.then u can see all the elemnt and they are pretty straigtfoward to chg.
Posted on Aug 21, 2009
Replacing burner on slide in FES365ECA frigidaire stove
Good Afternoon Friend,
I understand you are trying to get assistance on how to access the burners on your glass-top Frigidaire range, model# FES365ECA. I suggest contacting the manufacturer. They might have some type of diagram that will assist you in replacing the burner. My other suggestion would be to contact your local authorized technician for further assistance. The technicians have been trained to replace parts on your range. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Kitchen Ranges
Ples389dcb
PLES389DCB -- I have one of these too. The fan runs until the oven is almost ambient temperature. It seems to be normal operation for this unit.
Jul 25, 2013 | Frigidaire PLES389D Electric Kitchen Range
I am having new counter tops put in and need to move my Frigidaire Electric Range out. It is a PLES389ACD. I cannot locate any instructions on how to remove the range glass top. Could you let me know how...
Hi Larry. W/D here.
From the illustration given, you shouldn't have to remove the top from the oven, but take it out with the rest of the unit. Since it is a slide-in, all you should have to do is trip the breaker, slide the unit out enough to unwire it, and then pull it on out.
Best regards, --W/D--
Feb 10, 2011 | Frigidaire PLES389D Electric Kitchen Range
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
Where is the fuse panel located in Frigidaire Professional Series Slide in Cooktop range?
I can help , The fuse panel/control board is located behind the digital display in the front of the unit. Some drop in ranges are tricky getting into so be carefull when removing the face , there are screws under the display when opening the oven door look up and there may be a few more on the top side corners reveled when you pull the unit out 12" or so. there is a small glass fuse in the board some of these are not removable so if there is no digital display on your oven and your sure you have 240V to control board you will need to replace the entire control board. Hope this gets you there. Good luck let me know if you have anymore problems.
Phil
Dec 31, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
PLES389DCC Frigidaire Electric Range
I just replaced the top it is very easy if you know which screws to take out unplug the stove
LOTs of hidden screws so remember I only had 4 left overs.
First take the knobs off and the 4 black knobs below the real knob
Unscrew the black thing right under the knob this holds down the STEALESS steel cover for all your screws.
then start taking screws out of the fron the top sides and the screws along the oven door.
The screws near the top releases the glass and frame.
MARK COLOR CODE WITH MARKERS OR TAPE BUT DO IT BECAUSE you wont remember like me.
Wires unplug all of the connections that you see, P11 and P13 is where I had my problem they came off. the board eek
Be careful over lable I just exploded my stove when i put it all back together one wire came off I did not lable it.
239.00 for the board 289 for the glass
IF ANY WIRE COME OFF read the ciruit board Schematic
In still workng on my stove I cant believe it blew up the board.
KDH
Oct 27, 2008 | Kitchen Ranges
I am looking to replace the main glass top to a Frigidaire 30" Electrice Slide In Range - Model PLES389DCB. Before I make the purchase I want to be sure I can do this myself.
Hi there
You can get the part from here
It is not very complicated job to replace it. You, probably, will need somebody to give you a hand.
To start, remove the screws from the front of the main top holding it to the frame and lift it up. All burners are attached to the main top. Remove them one at a time, remove the indicator lights (they have the locking clips) and then release the main top from the hinges (under the control panel) and remove it.
Assemble all parts in the reverse order.
I found this info here. There is quite a bit of info regarding this procedure if you wanted to have a read up to get your confidence up:)
regards
Robotek
May 06, 2008 | Kitchen Ranges
Frigidaire PLES389D Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
