Question about Diesel Garden
Have a Mitsubishi starter for a small 3 cylinder (Toro Mower)
Have a Mitsubishi starter for a small 3 cylinder diesel engine (K3D)...starter part number (M2T56272) 12v. The starter throws out the 13 sprocket drive wheel but will not crank the flywheel. Out side of the engine the wheel throws out and spins rapidly. Spins... but seems to have no power to turn the flywheel. Whats my problem? Starter or power source...battery seems fine. Please advise.
Removed starter and tested with new battery and jumper cables...starter worked fine. Replaced battery and cleaned cable attachments...unit started as usual.
When starter throws this would indicate that the interconnect circuits are intact..the engine still would not turn...that leaves the battery, the cable, or a siezed engine. The engine flywheel turned easily...no siezure. That left only the battery and cable. Battery was 3 years old...cable was corroded...bad combination. Battery was replace and corrosion removed from the cable terminals...started first crank.
Posted on Apr 19, 2009
Where do I get motor parts for a self-propelled Toro lawn mower with an electric starter?
What parts are you looking for? you can usually buy parts at your local small engine repair shop or you can look for the specific parts you need on ebay. or google. just make sure that the parts you order are for your mowers specific model # which can be found on a sticker on the mower deck or stamped on the engine.
Mar 25, 2015 | Toro Garden
Problem with Toro self starter
remove the cover and look for a missing tooth on one of the gears
Mar 27, 2012 | Toro Power Lawn Mower
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Snowthrower. Won't even fire. Can I just clean carburetor?
See my tip on diagnosing small engines. It works for 2-stroke or 4-stroke engines.
It is best not to use starter fluid. Aerosol carb cleaner is what I use.
Jan 02, 2010 | Toro Lawn Mower With Toro Power Tools
Toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Toro GTS5 600 has not been used for 3 years, it starts on choke with a spray of engine starter then stalls out when choke removed Jim Slezak slezakj@yahoo.com
You will need to buy a carburetor kit and replace all appropriate parts. Use a Den Tek Brush,(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean the small portals in carb.
Jim
Jun 04, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
283 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Wade Mobley
Wade Mobley
Are you a Diesel Garden Expert? Answer questions, earn points and help others
