Question about Peavey CH1 Speaker
Peavey SP 4
I just recieved a used pair of these. They were obviously tampered with and were modified from thier original passive setup to a bi-amp configuration. I'm not a slouch with a soldering iron and was fairly confident that I could re-affix the respective leads to thier original factory set up. I first observed the (disregarded) high-end crossover coil with two black wires coming from it leading to a dangling female plug. Now, correct me if I'm wrong, but this should be between the POSITIVE powersource and the horn correct? And, if so, is the + the tip, or the shaft of a 1/4 in. input jack? I know this sounds like a dumb question but any-ones help would be greatly appreciated. Thanks, ..... Don
  • 476 Answers
I would like to understand you problem better,
Are you trying to repair the input to the speaker from the amp???
Please elborate thanks
Posted on Jul 21, 2008
  • Verne Koti Jan 14, 2009
    the jack tip is normally postive but you will need to check with the manufacturers setup specs,or you could try, www.dsc.co.nz and search the jacks images they normally have a spec sheet with their technical help line not far away,
    Hope this helps
Does anyone know how i should hook up a pair of peavey sp118 Bxsubs with a pair of peavey pr15 tops and the behringer inuke nu6000 please help
You will require 4 heavy gauge 1/4" speaker cables in order to connect all 4 cabinets to the Behringer power amp. Usually two longer ones from the power amp to the sub woofer cabs. Then two short ones from the second "thru" jack to the upper 15" cabs. Remember the entire audio frequency range is going to all four speakers. Sometimes you will have problems balancing the low frequency levels between all four cabs depending on the loading of each. A more desirable way to do this is with a bi-amped arrangement. This way two seprate amps are used for the subs and 15" cabs and you control them independantly.
Dec 23, 2013 | Music
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
Hi,I have 2 sp2 cabs,getting sound thru the horn but none to the speaker,any ideas ? thanks
2 possibilities here:
*Speaker coils got fried or,
*Input jack named "Low" in the Bi-Amp section has a loose contact, as they are switch also.
Hope this helps.
Sep 24, 2012 | Peavey SP2 PA Passive Speaker
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
Jul 28, 2012 | Peavey SP2 PA Passive Speaker
Peavey SP 5 speaker has stopped working
Check the crossover network for cracked solder joints, specially pay attention to the female1/4 jacks as they are very tricky since they are switches also, you might be surprised...
Apr 29, 2012 | Peavey SP 5 Speaker PA Passive
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
Whats the wattage of the bulb used in peavey sp2 crossover, my sp2 peavey speaker bulb is blown
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
Jan 11, 2011 | Peavey SP2 PA Passive Speaker
Caused speakers to smoke:(
If it's the speaker cabinet itself that';s smoking, you have most likely burnt some components in the passive crossover. Pull it out and you may see melted parts or scorching on the circuit board. Peavy does repairs on it's own products pretty reasonably if there's no local tech. Call Peavey Customer Srervice at 877-732-8391.
Apr 30, 2009 | Audio Players & Recorders
Peavey CH1 Speaker Logo
213 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
