Out put distorted with very low or nill output
I was using Behringer europower pmp 3000 to power the party last weekend, sudddenly the audio output went low and distorted, output was low and missing high frequency and sound was terribely distorted. There was no clipping and the volume was pretty high before it blew up.There is very low or nill output in one channel, the other channel is having distorted output. Please help Thank you Ateeq Sydney
  • 113 Answers
SOURCE: Behringer EP2500 no output on CHANNEL 1
check all op amps for correct voltage swing +-should be equal,test output of op amps no voltage should be present, use chasis gnd as tester neg.check voltage regulation especially 12v or 15v +-.note some amps show unequal led indications when only 1 channel connected to a load.I will try to get some more info on this specific amp because i don't know this circuit well,keep in touch as you update though.
Posted on Aug 22, 2007
  • 54 Answers
SOURCE: hafler dh220 power amplifier left channel distorsion
Sounds like your Power FET's are gone. Take it to a shop that specializes in high end or vintage gear. ....good luck...Rob
Posted on Mar 03, 2008
Grubhead
  • 5487 Answers
SOURCE: Sound from left channel is small and distorted.
The distortion might be caused by a resistor. The loss of volume could be the capacitors, but you could try injecting signals into the transistors to see if any has gone. They can cause the distortion and loss of signal. If you apply a soldering iron to any part it will heat up quicker, or you could also use a hairdryer for the whole thing. You can also get a freeze spray that cools things that have heat sensitive faults (available from electronic parts shops).
Posted on May 04, 2009
  • 5603 Answers
SOURCE: i have europower ep2500. for the first time in two
That side of the amplifier has a failure. It requires repair.
Posted on Jul 27, 2009
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
Volume is low when i use cd input
What kind of CD unit are you using? Is it a portable, rack-mount, stand-alone, or via computer output? This information is necessary. I will be glad to help otherwise.
Jan 10, 2013 | Behringer Europower Pmp1000 Powered Mixer...
Need schematics for europower pmp518m
Hello
I've with me the schematics for Behringer Europower PMP-3000 -PMP 1280 & PMH 518. If any one will suit for your set, inform me. OK.
Dec 28, 2011 | Audio Players & Recorders
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I want to know how to send the signal from a Europower pmp 3000 to two external amps
Plug a balanced TRS (tip ring sleeve) cable into either main or monitor 1/4 inch jacks and then into the amp. ALWAYS use balanced lines AND power the mixer AND the amps from the SAME receptacle to avoid damage from ground loop bounce,
May 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Feb 05, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Jan 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
Jun 08, 2009 | Behringer EUROPOWER EP2500 Amplifier
177 people viewed this question
 Grubhead
Grubhead
