Question about Gateway M-6340u PC Notebook
I just received new gateway t-6340u notebook, the issue I'm having is when I start my notebook from a shutdown mode the wireless router is located and no problem. But when I command a re-start the wireless router is not found, the only way it finds it is if I turn the wireless switch off for about a minute then switch it back on. Within seconds I'm back on line. Talk to Gateway and we re-installed drivers, no help. Is this a come problem? Also will this cause more problems later. Thanks TC
  • daboyzxxxll Apr 14, 2009
    Thank you, it works when I right click and hit repair. Do you think this will cause a problem later?
  • Gateway Master
  • 32,281 Answers
What you are doing is OK. The problem is when you re-start the wireless card has lost it IP address and when you switch it off and on again the router issues the wireless a new IP address.
You can also get the router to issue a new IP address by right click on the wireless Icom on the Task Bar and left click on Repair.
Posted on Apr 13, 2009
  • Chris Hingee
    Chris Hingee Apr 14, 2009
    This will cause no problems, from time to time this problem will occur again, when it happens just click Repair.
I cannot connect to my belkin connect n150 router after enabling it as an access point. Green light shows up on router and wireless network shows up but no connection when clicked. I cant connect via
Pretty sure you have to have at least one router in gateway mode to connect to the internet. An AP allows wireless devices to connect to a wired segment. The same as a router in gateway mode. AP mode has the benefit of extending a networks wireless range. If this is your only device leave it in gateway mode.
Jan 28, 2013 | Belkin Basic Wireless Router
I need to change my linksys routher password how to change?
Hi Friend,
If you want to change the password for router login page then please follw the steps:
1. Click Start \ Run\ type cmd and hit enter
2. In the black window typ the command ipconfig and hit enter.
3. Note down the default gateway and close this window.
4. Open the web browser and type the default gateway and hit enter.
6. The default password is admin and leave the username blank.
7. In the router setup page click Administration
8. In the left pane you will see Router password. Type the new password and re-type it. Then click save settings and turn the oruter off for 30 seconds and then try to login with this new password.
If you want to apply security on your router, so that no one can use your network, then please follow the steps:
1. Open the web browser and type the default gateway and enter the password.
2. Click Wireless and then Wireless Security.
3. Select WPA Personal from the drop down of Security mode.
4.WPA Algorithm should be TKIP
5.Type any ten digit number as the Shared key and note it down and click save settings.
Turn the router off and switch it on. Now whenever you try to connect your wireless devices use the shared key as the security key.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 14, 2010 | Linksys WRT54G2 Wireless Router
New d-link router ,how wireless configuration lan internet acess complte but wireless not found pls help me kindly
Hi Friend,
Please follow the steps:
1. Click Start\ Run\ type cmd and hit enter.
2. In the black window type ipconfig and hit enter.
3. Note down the default gateway and cloe this window.
4. Open the web browser and type the default gateway and hit enter. Enter the username and password.
5.Click Wireless and then click Manual Wireless Network Setup at the bottom.
6.Make sure you fill/select the fields as mentioned below:
* Check the Enable box and note down the PIn.
* Wi-fi Status must be Enabled/Configured
* Check the Enable Wireless box
* Wireless Network name: As per your choice
* Select the last option from the drop down of 802.11 mode
* Check the Enable Auto Channel scan box.
* Select Visibility Status as Visible.
* Security Mode : WPA Personal
* WPA Mode: WPA Only
* Cipher Type: TKIP and AES
* Group key : 3600 seconds
* Pre-shared key : Any ten digit number (note down this number)
Once you enter informations click Save Settings. Turn off the router for 30 seconds and switch it on. Use the pre-shared key whenever yu try to connect any wireless devices.
Regards
Chiranjeet
Dec 09, 2010 | D-Link DIR-600 Router
My computer is showing the conection but not letting me on the internet how can i fix it?it says conneted and says no internet access.
1) try turning off and restarting the modem and router.
2) if you are using a dsl connection check if the modem is in bridge mode with your isp.
if yes then
type click on start->run->cmd and press enter
in the black window type ipconfig
now note the default gateway and type the default gateway in the internet explorer Eg \\192.168.1.1
check if the router is set to connection type as pppoe.
enter your usernaem and password and save the internet light will go on.
if the modem is not in bridge mode then try connecting you pc directly with the modem and check if the internet is working not not. if not contact your isp for settings.
if internet is working fine.
not connect your router to your modem and then your router to your computer.
check if the router is set to optain ip automatiicaly and save changes.
if you still face any issue let me know.
Jul 05, 2010 | Linksys Wireless-G Broadband Router
After shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Apr 07, 2009 | Gateway MX6441 Notebook
Wireless connection
Gateway should have it's own software but...you can start with Connect To on the Windows Start Menu and choose wireless connection.
What OS?
Mar 31, 2009 | Computers & Internet
My wireless capability button is broken on my gateway laptop.
ok so my wireless switch wont turn on i have a new gate way laptop was working fine yesterday
Mar 20, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My Gateway m-6340u has interference coming through the speakers
The only way i know of would be to take the laptop apart and improve the ground from the motherboard to the chassis, since this is probably where the problem is coming from in the first place.
Jan 19, 2009 | Gateway M-6340u PC Notebook
Unknown Wireless Router
Sure U could give it a try!!
With the computer wired with the router - checked the IP address and the default gateway
Start - run - cmd - ipconfig
once you get the default gateway(say for eg., 192.168.2.1)
type the DG in the web browser andcheck for the options!!
Dec 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connecting wireless
Based on the category you picked I need to ask if you want to connect a wireless adapter in a computer to the one wireless router you have or do you have such a large area that you need two wireless routers to cover the space. They are two very different issues. Please add a comment to this issue if you really have two routers -- it is a different problem than the one I will describe.
Assuming the picture of the device is right and it is another wireless adapter you need to connect to the router.-- the simple answer is basically the same as the ones before which is probably not helpful now. (Assuming the wireless adapter is installed and the drivers loaded.) Then if you have an secure network (where WEP or WPA was enabled) you probably will need to connect to the specific network using your adapters manufacturer's software or Windows Wireless Zero Configuration where you will probably need to supply a network name (SSID) and the passphrase that was configured inro the router. If you have an unsecured network your adapter may work without configuration. There is one other possible issue -- most routers dynamically assign ip address and other information to the adapters. If your router was not configured to supply all information including DNS addresses we may have some additional configuration to apply to the wireless adapter.
Please respond if these steps are two complex so I can provide additional information. Please provide the manufacturer and model of the wireless router and wireless adapter if that is the case so I can provide more detailed information specific to your hardware.
Jan 04, 2008 | Linksys Wireless-G WGA54G 802.11g/b...
Gateway M-6340u PC Notebook Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
