Question about Kenwood KAC-8101D Car Audio Amplifier
How do you determin how many farad capacitor you need for your car system?
  • pelikant75 Apr 14, 2009
    Do you mean per 1000 watts?
You only need one farad per 1000 amps
Posted on Apr 13, 2009
  • davis9427 Apr 16, 2009
    sorry, yes.
Crosley CR2405B , cassette player worked ,,, now it does not , very little use,,, I just hear a hum
There is a swollen capacitor in the power supply section that needs to be replaced.
Replace it using the same farads and volts.If you cant get the same capacitor value that use get one that has the Farads but voltage can be the same or abit of a higher value.
Good luck and thanks for using Fixya.
G
Jun 14, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Need wiring diagram for tsunami 1.2 farad capacitor cap.
After a bit of searching I found the instruction manual:
http://a248.e.akamai.net/pix.crutchfield.com/manuals/120/120pp912u.pdf
Hope it helps.
Mar 05, 2011 | Metra Tsunami 1.2 Farad Capacitor
It's beeping when turned on. Why?
I have read that if the polarity is reversed, or the connections are backwards, the Capacitor will beep. If this is not the case, it may need to be replaced.
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
Need diagram to install capacitor
Hello tommysgirl,
Here's a link to Car Audio Help's cap wiring diagram.
Hope this helps.
Aug 27, 2009 | Power Acoustik 1.2 Farad Capacitor Pcnc...
Diamond wire diagrams for capacitors 3 0 farad
i think you mean you want to know how to wire 2x 3.0 farad 12V capacitors into a 24V truck??????? let me know i can help with this,ben
Aug 13, 2009 | Car Audio & Video
Capacitor
You usually don't need a capacitor because your car can keep up with the power requirements, especially since your system isnt too big (no offense). But if you wanted to get one, i would only get a 1/2 or 1 farad cap.
Jul 26, 2009 | Legacy LA588 Car Amp
Lights dimming
Your lights are dimming because your system is pulling too much current from your car. Your battery provides long-term sustained power, but your system wants to draw power faster than your alternator and battery can provide it. When the amp attempts to draw more amperage than the battery and alternator can produce, it creates a voltage differential in your system, which attempts to steal electricity from the rest of your system (like your lights). The most common solution for lights dimming is to add some level of adequate capacitance to your car. Capacitors store electricity and deliver it quickly to your amps as needed. Capacitors resist voltage changes by producing large amounts of amperage. This means that the capacitor(s) will provide the electrical bursts that your amps want so that it doesn't have to steal it from your lights. You can start out with 1.0 Farad, if the problem doesn't go away, add another one, and so on until the problem is gone. You cannot have too much capacitance, it's just an electrical buffer for your audio system.
May 14, 2009 | Jl Audio 13W7 Car Subwoofer
Adding aftermarket audio to factory amp.
yes it will kill your batery u need aremote turn on man dont messa round with out one
Feb 03, 2008 | Car Audio & Video
Blown capacitors
There's hundreds of capacitors in an amp... The value should be printed right on them. It will have a Farad rating (F) or usually MICRO farad (uF) and a voltage rating (V). Looks like "16V 47uF"... Be aware that there's likely to be more problems than just the caps...
Sep 20, 2007 | JBL GTO 301.1 Car Audio Amplifier
Kenwood KAC-8101D Car Audio Amplifier Logo
948 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
