Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
I want to clean out my hp
I need to find out what i need to do to take off the outer case of my hp slimline 7520n so i can air away all the dust that might be inside in the harddrive. can you give me step by step instructions?
  • 31 Answers
Hp desktop alarming when turned on
Open the lid. Blow (or vacuum) dust away from CPU heat sink.
Take out RAM clean the edges with thick cloth. Put back and try again.
Jun 17, 2014 | HP Hewlett Packard Pavilion Slimline...
Hp 6830s is to nois. Fan is tooloude
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air.
You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
Mar 04, 2014 | HP Presario Computers & Internet
HOW MUCH WOULD THIS 7520N BE WORTH TO SELL
looks like this unit is going for $250-$399 on the web......
Jun 28, 2011 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Casing getting hot, fan going mad then slowing down
Have you ever removed the side panel and cleaned out the dust from inside the computer case?
If your fans or air inlets get clogged up with dust then your machine will run very hot and could eventually shut down or cause permanent damage.
Unplug all the cables from the back of your pc, and remove the 2 screws from the back panel that secure the side panel. Then just pull back on the side panel and it will pop off.
Clean out all the dust from inside the case. You can use a vacuum hose but don't bang into anything with it. Also use a small clean paint brush to lightly brush the dust off of the fan blades and the CPU heatsink and around the power supply air vents. You can also use a can of compressed air if you have it to dislodge the dust and then **** it up with the vacuum.
Good luck and please comment back and RATE if this was helpful.
Feb 05, 2011 | HP Pavilion Slimline s3500f Desktop...
Shuts down randomly. Has been cleaned of dust,
Hello there...
I've been experiencing similar problem once.
In my case it was caused by faulty Network Interface Card, if you have a PCI Network Interface Card try temporarily remove it from the PC and then use the PC as you would normally do.... and see if it still shutdown randomly.
And if after test there is no random shutdown occurs, consider to replace your Network Interface Card.
Hope that helps... :D
Apr 13, 2010 | HP Pavilion s7600n PC Desktop
My HP Slimline Desktop s3120n turns on and as soon as goes on it turns itself off.
it seems your computer needs cleaning and servicing, my advice is to open your pc and use dust cleaner,you can buy a can from any computer outlet, spray all the dust out also all fans,the heat sink on the CPU,make sure also the fan that is connected via the CPU,I believe dust has accumulated between the fan and the CPU,by this the cpu cannot read the from the hard drive all because of so many dust that has accumulate between the cpu, it hard to read the data from hard drive and CPU.
hope this work for you.
Jan 20, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Won't Start
This happened to my to my HP Media center Edition PC. I'd have to unplug the power from the outlet, let it stop flashing and the power up again. It would run for a short time and then shut off with the annoying amber / blue flashing light.
I found it was a heat problem on mine - specifically, the CPU cooler. After shutting down and opening the PC, check to see 1) if the CPU fan is running smoothly and 2) if there is a lot of dust and dirt on the CPU cooling fan and heat sink (and rest of the case for that matter).
Gently clean / vacuum the insides of the case AND power supply as best you can. Carefully vac the fan blades and heat sink to clear the dirt and dust that prevents the heat from being blown away by the fans.
When complete, you might even want to take the PC outside and reverse the vacuum so that air can be blown into tight places in the case. A can og compressed air can do the job instead, too.
Reassemble and start up as normal. Good luck!
Sep 18, 2009 | HP Hewlett Packard Pavilion Slimline...
Video freezes up to vertical lines or blue or white screen
Clean the CPU cooler and everithing else from the dust!
Turn off,open the case, use air spray to clean.
(I use vacom cleaner and a small brush, but you risk your component if you do the same! I'm professional.)
Nov 27, 2007 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
260 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
