Question about LG LRTBC1825T Top Freezer Refrigerator
My LG freezer is cooling while the refrigerator doesnt.
I bought this freezer 2 years ago. Recently I found the refrigerator is not cooling while the Freezer works OK.
  • htshprasad Apr 12, 2009
    I tried changing the thermostat settings to minimum for almost 12 hour and then to maximum, however no improvement.
  • JEFFrey BAKER
    JEFFrey BAKER May 11, 2010
    DID YOU CHECK YOUR THERMOSTAT SETTING ? PUT IT TO THE MIDDLE SETTING THEN THE COLDEST SETTING JUST TO MAKE SURE ITS NOT THAT THEN WE'LL GO FROM THERE
  • 294 Answers
OK THEN FROM WHAT YOU SAY SINCE THE FREZER WORKS BUT NO FRIDGE IT SOUNDS LIKE A DOOR SEAL FOR THE FRIDGE DOOR GONE BAD,DIRTY,WARPED,OR WORN OR THE DOOR IS'NT SHUTTING ALL THE WAY THIS IS THE NEXT STEP OF WHAT TO LOOK AT
Posted on Apr 13, 2009
Why is my LG LFX25980ST is not cooling any more?
Hi John,
are all the lights on??
if yes, check for fan fuctionality and ice build up inside the freezer portion if freezer is warm, then either the compressor electronics or your cold control could be bad. Also the LG fridges have some issues with coil leaking.
so first look at that and if is warm try to check if the compressor works.
hope this helps!
Jun 03, 2014 | LG Lfx25980st French Door Refrigerator...
I bought a French 3-door Refrigerator about three years ago and the freezer recently stopped cooling and then the refrigerator stopped cooling. The refrigerator runs but doen't cool. Any help here?
Yes. You have a faulty automatic defrost cycle. If you manually defrost the freezer, then restart the fridge and it is back to normal. It is a sign that the defrost is faulty and you will need a technician to fix it for you
Apr 04, 2011 | LG Refrigerators
Why is there heavy ice buildup in our 2 year old LG bottom freezer refrigerator model LFX25970
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | LG LFX25960 Bottom Freezer French Door...
Please help me to troubleshoot my LG expresscool brand refrigerator, i bought this two years ago in the local refrigerator distributor in our place here in the Philippines. Last week, we experienced...
in the back there is a cover and under there is a pc board / it may have burnt the board and will require a replacement . ck the glass fuses on the board . and if one has gone bad then rep the board . you could refuse the board . but this diesn't always work . as they didn't make the be refused .. mm
Oct 22, 2010 | LG LRTBC1825T Top Freezer Refrigerator
2 year old LG refrigertor doesnt cool inside is warm and the bottom freezer doesnt work either. outlet is ok. the light inside the refrigerator works.
Your run capacitor is bad which is the plug attached to your compressor or you have a leak in the system. If your compressor is not running after you put a capacitor on then your compressor is fried. Good luck. Rate me if I helped you!
Aug 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
LG Refridgerator LFC257060ST Keeps Beeping
Please check whether the doors are aliened properly to the body and if there is a small warp it could result in escaping of cooling resulting in poor cooling of both the freezer and the refrigerator chamber.
The magnetic gasket is the next reason for poor cooling. So please ensure that the gaskets are having magnet attached to the full length. Broken magnetic strip inside the gasket could also result in partial closing of the door leaving behind plenty of gap allowing the cooling to escape.
Just insert a visiting card between the gasket and the body and if you could do so then the gasket is not effective and requires replacement.
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
LG LRTBC1825T Top Freezer Refrigerator Logo
293 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
