Question about SAIT Portable Saw Cut-Off Wheel TM 12 x 1/8 x 1 BRUTE
Any way to take apart cemented pvc drain pipe
Prior owner put drain pipe under sink with no trap and cemented all the pipes together, reluctant to cut/saw apart, as not much main plastic pipe left in the wall.
  • 50 Answers
If the drain is slow or stopped up, i use a high powered drain opener from ace hardware called "liquid fire" it is different from drano and all that other ****.
Posted on Apr 13, 2009
  • 4 Answers
PVC is not cemented or glued together. A solvent melts the surface or the PVC and when the two pieces of PVC are put together and the PVC hardens they become one part. There is no practical way to separate them.
Posted on Mar 04, 2013
I have a Badger 5xp & a double sink. When I turn the disposal on I get a small eruption of water, air and disposed of debris from the other drain.
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 24, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal is about 2-1/2 years old It is now no longer grinding up potato peels and clog every time! HELP--do we need a new one!!!
1/2 horsepower is the lighter weight model, and if you use it heavily, then it will not work like before.
Another thing to consider is whether the water is draining away completely while you're cutting.
If water and potato peels are both present, your p-trap and tubular drain may need to be cleaned.
Let's go through the whole thing: replacement, p-trap, tubular pipes, everything.
That way we didn't have to change out sink basket or move pipes around.
How to replace disposal body: Disconnect both nuts on p-trap. Remove p-trap and loosen tailpiece going into disposal.
If this is your home, you might want new sink basket that comes with new disposal because it looks shiny and new.
On image above, loosen both nuts on p-trap, trap falls loose, and then work on disposal.
Add a comment
Dec 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
While using our garbage disposal this afternoon, it went from grinding to humming. The blades do move freely, but the plate is very loose and tips. Is it possible to tighten the plate?
There is no way to tighten plate that I know of.
Maybe a clever welder could stick it back together, but the problem implies something underneath is rusted out or broken. The main thing is the cutter plate, and if disposal wobbles, it will loosen drain pipes under sink and cause dripping.
I wrote some tips for installing new disposal, and include them here since disposal will be replaced at some point.
That way we didn't have to change out sink basket.
How to replace disposal:
Make sure there's enough putty that it squeezes up all around sink basket.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Add a comment
Dec 06, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I put too much carrot skins down the disposal , the blades turn but the water will not drain
You have to take apart the tubular drain pipes located under sink.
It will be fun.
Here's some do-it-yourself information to save calling plumber.
Take apart tubular pipes and clean them out.
Take a photo of the drain before starting. Take other photo as needed for facebook.
Once pipes are apart, run water or use coat hanger to clean out disposal.
Not necessary to take disposal out.
1) Tubular pipes connect to disposal.
Each tubular pipe has a nut and washer.
Pipes can be metal with rubber washer.
Pipes can be plastic with plastic washer.
2) Tubular pipes come apart with channels locks
3) You need a bucket to catch the water when you take apart tubular pipes.
Keep towel handy.
4) All tubular pipes that get moved while working under sink have to be taken apart, cleaned and re-assembled. All you do is take them apart, clean them out, clean them up, and re-assemble the same way they came apart.
5) Take a photo of the drain assembly before starting. Always start with the P-trap shown image above. Loosen top nut and lift up nut. Next, loosen tubular pipe that connects to disposal. and see it can lift out of P-trap without moving any of the other pipes. If clog is inside p-trap, then p-trap will have to come off. Try not to move any other drain pipes; any drain pipe that gets moved will start to leak and needs to be taken apart, cleaned and re-assembled.
6) For best results:
After clog is removed,
Clean all tubular pipes and washers before re-assembly. Take photos as you go so you know where each part goes.
Plastic washers are re-used.
Flat part of plastic washer fits against nut, tapered part away from nut.
Rubber washers can be re-used depending on age >> new rubber washers are best.
7) To re-seal tubular pipes first-time every-time, use rectorseal on rubber or plastic washers.
As you are re-assembling, smear healthy amount over entire washer and then tighten the nut.
Wipe off excess on outside of pipe.
Add a comment if you have a problem.
Nov 21, 2010 | Electrical Supplies
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Bathroom drain pipe has no threads
I 'am having a hard time visualizing this problem ? is your drain line a PVC pipe or is it the old style brass that was once used?
Jul 26, 2009 | Plumbing
Cement sink drain repair
Yes you can still get those basket strainers and you can replumb with plastic pipe. Make sure when you go to the store to get the extra long strainers made for thick sinks, the fitting on the bottom should be made to accept plastic pipe. You may also need a "mission band" or "fernco coupling" to attach the plastic to metal pipe after replacing everything under the sink.
Mar 23, 2009 | Plumbing
1 drain pipe with 2 traps
eyohe
Please read and understand these entire posts and collect all tools & materials before beginning this project.
Materials needed:
2 - PVC 1-1/2" compression x 1-1/2" female Schedule 40 solvent        weld trap adapters.
2 - 1 1/2"PVC-DWV ADJ P- traps (serviceable)
1 - PVC 1 1/2 X 1 1/2 X 1 1/2 sanitary Tee
1 - 90 degree PVC short turn elbow
1 - 4' piece of 1 1/2 PVC sched. 40 pipe
1 - 4oz can Oatey PVC Regular Clear Advanced Cement
1 - 4oz can Oatey PVC Clear Primer
1 - Small container plumbers putty (To be used as a gasket like bushing between the disposers basket strainer and the sinks surface)
Tools that are needed:
Safety glasses
Latex gloves
Hacksaw
Torpedo level
Measuring tape
Channel locking pliers
Sharpie type pen/marker
Old work rags to clean the edges of freshly cut PVC pipe of loose debris.
Old newspaper to protect your floor/work area and the floor of the sink base.
Any other tools listed with the disposal installation instructions.
Feb 19, 2009 | Plumbing
Im having a problem desiding how to hook my drainage pipe up from the dishwasher i cant put it next to the sink cause theres no room so i have to put it on the other side of the kitchen could i connect new...
you can put a new verticle pipe up from under the floor and put the drain hose in that. make sure the vertical pipe comes up to about worktop level and make sure there is a water barrier in it or you will get a nasty smell
Sep 04, 2008 | Dishwashers
SAIT Portable Saw Cut-Off Wheel TM 12 x 1/8 x 1 BRUTE Logo
909 people viewed this question
Top SAIT Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a SAIT Saw Expert? Answer questions, earn points and help others
