Question about Hilti Drills
Where can I find manuals on hilti hammer drills, both older and newer models. Such as amperage ratings? the larger models te52 and bigger. Thanks
    Sniper:
  • 61 Answers
I willgladly email you schematics however TE52's are very old and parts are no longer available for this model
paul@wysehire.gi
www.wysehire.gi
Posted on Dec 13, 2009
  • 2,176 Answers
Call Hilti direct at 1-800-879-8000 and speak to one of their techs. Hope this helps If not let me know and I will go a different route.
Posted on Apr 22, 2009
Can i still get inside parts for my hilti te 52
No the parts are no longer available for the TE52
Mar 05, 2013 | Drills
Hilty TE 12 Hammer Drill Wont Hammer, but will run
Parts are no longer available for the TE12. Be carefull if you try to take it apart yourself. Some of the older models had a lead based grease in them
Oct 26, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I have a hilti te52 and they were pounding a ground rod in with it and the end in the chuck mushroomed over and now we cant get it out what do we do.
the only thing you can do is try and tap the hammer away from the ground rod. they make a ground rod adapter for this instead of just inserting it in the tool. If this doesn't work you will have to remove the nose and the striker and then drive the ground rod out of it.
May 16, 2011 | Hilti Drills
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
I have a hilti TE52 I need a handle grip for it please E-mail me @ brewerkent99@yahoe.com
you can go to Hilti.com and find a dealer/service locator close to your location or call them direct at 1-800-879-8000. I am not allowed to respond directly to your email. Let me know if you still have problems.
Mar 10, 2010 | Hilti Drills
Will hammer but not drill model te52
If it drills in the air but stops when you put it into concrete then the clutch is worn out. If it will not turn at all it could be stripped gears. Unfortunately Hilti no longer carries parts for that model.
Oct 01, 2009 | Hilti Drills
Hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Jul 02, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Trying to drill a solid concrete 10 inch wall
the ideal sollution is to fully service the machine but there may be a quick fix.
remove the 4 screws that hold the black plastic handle assembly, and take the handle off. on the top of the drill you will see an oil filler cap. unscrew using a 10mm allan key.
empty out any old oil. rinse out with some parafin if you like. empty out again . put some new oil in and replace the cap. 50cc of transmission fluid / power steering oil will do the trick. if this dousnt fix it then you will need to replace the o-rings on the pistons, if this is the case, drop me a email and I will send you a parts diagram. paul@wysehire,gi
good luck.
Jun 02, 2009 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
Hilti Hammer Drill 76p atc wont spin, has flashing led
Sounds like it needs new brushes. Schematics can be found on hilti.com. tech support - rotary hammers/ combi. Look up model number. Some of the older stuff is obsolete. Should find info there.Please rate me
Apr 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
575 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
