Question about Pentax Optio A10 Digital Camera
When 4 gig. sd hc memory card is loaded into camera CARD IS IN ERROR msg. appears on lcd screen. Any ideas???
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
The A10 uses SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with the A10. You need to use SD cards, 2GB and smaller.
Posted on Aug 25, 2012
  • kakima Aug 25, 2012
3 Suggested Answers
old marine
  • 1979 Answers
SOURCE: maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Posted on Feb 24, 2009
  • 149 Answers
SOURCE: Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
Posted on Sep 09, 2009
Can I use a 4gb sd hc memory card in a canon powershot s2 1s? the screen says there's a memory card error
The Max. Memory Size of ur camera is : 2048Mb/2GB.........That is reason for which it says that there is a memory card error.
Feb 17, 2011 | Canon PowerShot S2 IS Digital Camera
Put new optima sd hc memory card in screen says memory card error
Sorry but the A400 was designed well before the SDHC format came out. Your camera can only use standard SD cards (2GB or less).
May 05, 2010 | Canon PowerShot A400 Digital Camera
Why can't you use 8GB memory card in Z710
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
Jan 20, 2010 | Cameras
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 19, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
I have loaded a new memory stick and get a message "memory card error" I have since tried another card and get the same maessage. Any idea waht the issue is.
Well if your camera is an SD600, I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 17, 2009 | Canon PowerShot SD600 Digital Camera
My acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
Oct 05, 2009 | Acer Aspire 3680 Laptop
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
MEMORY CARD ERROR
Camera is not recognizing any memory card. The issue is with the camera electronics and not the cards.
Jun 20, 2017 | Sharp Viewcam VL-NZ150U Mini DV Digital...
Pentax Optio A10 Digital Camera Logo
98 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
