Tape drawer will not open
Unit turns on but tape drawer does not open
  • David Dunn
    David Dunn May 11, 2010
    Please provide some details - Specific model, what works, what doesn't.
I turned the unit on it's side and operated it that way. The tape drawer opened and the readout reverted to normal. After that I operated the unit for a while and then turned it back to rest on it's bottom and so far it still works.
Posted on Apr 13, 2009
Hi8 tape is twisted in the cassette drawer. Cassette drawer (tape carriage) will not open now. I can hear the hydraulics whirring when it is turned on. But the tape carriage will not rise so I can remove...
Its a common problem and its easy to do but I suggest go to a repair place. They can do it in 1 minute and charge u minimum or nothing. I would not leave the camera there
Sep 26, 2017 | Sony Handycam CCD-TR416 Camcorder
A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Jun 01, 2010 | Televison & Video
Sony camcorder drawer has jammed open
problem solved by friend who found a by-pass socket for charger on camera which charged battery enough to close tape drawer. Thank you
Jan 07, 2010 | Sony Video Cameras
StorageTek L20
Yes, you can open the CAP. I believe the menu has a function for that, like Select to Open CAP.
Apr 02, 2009 | Storagetek L20 DLT Tape Drive
Looking for some further insight into 'Error 03' messages
HI...
The unit will need to have the cover pulled off and the tape drive mechanism unfastened , turned over and,the VERY small belt needs to be replaced
SBO1.55 belt from www.studiosoundelectronics.com
Mar 20, 2009 | Tascam DA-30MKII
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Cleaning dispenceser drawer can't open
Unfortunately the screws which hold the dispenser to the machine are located behind the drawer which at present you are unable to open. As you say you have the top cover off, you might try shining a light into the top side to see if you can see where the hang up is, and then drilling a small hole in the plastic and poking something through to move or dislodge the blockage. A small hole could be resealed with foil tape or silicone, or the dispenser housing replaced once you are able to remove the drawer and access the mounting screws.
Nov 14, 2008 | LG WM-2277HW Front Load Washer
Much loved old J.V.C. unit
Sounds to me like the belt drive is slipping!
Need to open her up and check tightness of belt and probably try to buy another one which will be tighter!
Mar 21, 2008 | Audio Players & Recorders
Fisher & Paykel DD603ZW DishDrawer - Leaking.
I removed all internal pieces from the drawers to make them as light as possible. Then removed the securing screws, 2 each side at lower drawers. (These secure the unit in position in its cove. Slide out bottom drawer and loosen height adjust screws each corner to lower unit and then slide out. I taped the drawers closed so they wouldn't open as I moved it. I lifted the front and put a heavy rag under the front legs which helped me draw it out. It helps if you have a second pair of hands. As you edge it out, ensure power and water supply hoses are clear of any obstructions. it's not that heavy just unwieldy. Chers, Craig from OZ.
Mar 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Canon zr300 ejects tapes
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Dec 04, 2007 | JVC GR-D250 Mini DV Digital Camcorder
 Grubhead
Grubhead
